First post, by Lylat1an
I just ordered an FIC KA-6100 motherboard, then realized that its VGA output won't be compatible with my modern monitor.
https://theretroweb.com/motherboards/s/iston-ka-6100
What's a good AGP 3.3v video card that has a DVI port, has drivers for Windows 98SE with 1920x1080 resolution, and will also work with Windows 3.1, and DOS 6.22?
Reply 1 of 16, by darry
Radeon 9700 and 9500 series and older (9550 and 9600 variants are not 3.3v AGP conpatible, some variants of the 9800 are but hard to find and not easily identiable, AFAICR).
On the Nvidia front, the higher end Geforce FX series are options.
See also https://www.playtool.com/pages/agpcompat/agp.html
EDIT :
See also 440BX AGP experts, let's settle this once and for all.
EDIT 2: For Windows 3.1, you would might want to consider something like this https://bearwindows.zcm.com.au/win31x.htm
Reply 2 of 16, by leileilol
The "3.1 / 6.22 drivers" throws a wrench into this. They were dead long before AGP.
long live PCem
Reply 3 of 16, by Lylat1an
leileilol wrote on 2024-04-19, 03:38:
Might any AGP 3.3v cards simply display video properly without drivers DOS/3.1?
(Edited original post to clarify that I only need 1920x1080 in Windows 98SE)
Reply 5 of 16, by darry
Lylat1an wrote on 2024-04-19, 03:54:
You don't need drivers for DOS games and demoscrne demos (320x200 256 color ones) to work, but you will hit limitations/issues on newer cards with things like wrong aspect ratio (which your monitor might be able to compensate for), soft/blurry forced scaling on Nvidia cards if using DVI, complete incompatibilities (on Radeon cards, especially). 70Hz mode being run at 60Hz and either reducing apparent motion smoothness or even slowing down audio to match (Second Reality). This last one can be addressed with a custom programmed EDID emulator.
The above are just off the top of my head and I can share some links to forum discussions on them if you are interested.
For Windows 3.1, on newer cards without drivers you will get 640x480 in 16 colors. The link I shared in my previous post provides an alternative driver ( I believe there may be others) that should allow 256 colors in higher resolutions on cards with VESA VBE support when using Windows 3.1, which most if not all of newer cards you might consider have (it is buggy in some of them, though).
Reply 6 of 16, by Lylat1an
Suppose I didn't use 3.1 and stuck with DOS and 98SE, would DVI and DOS drivers still be an issue?
And what cards even had DVI in the late 90's? I'm only seeing two options for TNT2s and I'd either have to import it or pay a lot more.
Reply 7 of 16, by marxveix
Some Geforce2 cards have DVI output and Mac versions of ATi Rage 128 Pro has DVI, but they both do not have Win3.1 drivers. Rage XL is latest from ATi with Win3.1 support and TNT2 from Nvidia, that was mentioned before, with Dos and Win9x they are both good, Geforce2 is better card overall for DOS and Win9x than ATi Rage 128 Pro.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 8 of 16, by theelf
Riva 128 have incredible DOS vesa3, good Win3x drivers with DCI support and win9x drivers
No idea about DVI
Some Geforce have dvi, all exelent vesa3, win9x drivers, and can use patched 256 colors vesa win3x drivers
Reply 10 of 16, by darry
Lylat1an wrote on 2024-04-19, 19:21:
There are no DOS drivers for to use VGA functionality, nor are any needed because DOS games and applications talk to the video card using either VGA BIOS calls or by directly accessing the hardware. To use SVGA capabilities, the application or game must either support the specific hardware directly (very rare since the late 90s except for some early 3D accelerator cards for the 3D functionality) OR talk to the SVGA using VBE (VESA BIOS EXTENSIONS) which is a standard that nearly all SVGA cards from the late 90s implemented in their video BIOS, so no drivers required).
The below caveats, that I had previously mentioned, apply to software using VGA (not SVGA) functionality.
Reply 11 of 16, by darry
Using an AGP card for Windows 98 and a different one for DOS and Windows 3.1 is an option, by the way. Many motherboards allow selecting either an AGP or PCI video card as the primary card in the BIOS setup.
I use an AGP Geforce FX 5900 over DVI and a PCI Voodoo 3 over VGA (with an OSSC to digitize its output into DVI). The FX 5900 is used in Windows 98 whereas the Voodoo 3 gets used in DOS and in Windows 98 when preferable (Glide games, old Direct3D games).
Reply 12 of 16, by Lylat1an
I'm back again,
I'm not having much luck finding a good TNT2 card with DVI:
So I'm curious whether any ATI card(s) might be advised that were available with a DVI port, DOS compatibility, and Windows 3.11, and 98SE drivers?
Reply 13 of 16, by rasz_pl
Lylat1an wrote on 2024-04-23, 01:49:
I dont think there ever was one?
How about trying your luck with one of those Chinese $5 VGA to HDMI adapters?
https://www.ebay.com/itm/156098959647 https://www.ebay.com/itm/374806655675 etc
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 14 of 16, by Joseph_Joestar
You may want to check this thread, if you haven't already: Best video cards with DOS / Win 3.x / Win 9x support
As noted previously, DVI is not a good fit for DOS games, as it can cause slowdowns and stuttering. Natively, most DOS games run at 70 Hz. However, many DVI implementations from the late 90s/early 2000s force DOS games to run at 60 Hz, which causes the aforementioned issues.
If your need for DVI comes from using a modern display, then you might want to look into converters or scalers, as others have suggested. The best (but also the most expensive) solution would probably be the RetroTINK 4K.
Reply 15 of 16, by Lylat1an
Well, I DO want the DOS games to run well, so I'll cave and use a VGA port.
Do you guys think I'd be better off with a Riva128, or a TNT2?
If I should go the TNT2 route, should I splurge on a Pro or Ultra variant?
Reply 16 of 16, by Joseph_Joestar
Lylat1an wrote on 2024-04-23, 03:35:
AFAIK, the TNT2 drivers for Win 3.1 aren't very stable. If you want good DOS game compatibility, functional Win 3.1 drivers and excellent image quality, go with a Voodoo 3. Sadly, those cards are quite expensive now, so that's a pretty big issue. In terms of Win 3.1, Voodoo 3 cards will happily work with Velocity drivers. They are also great for Win9x.
Another card from that generation which has proper Win 3.1/Win9x drivers and exceptional image quality is the Matrox G400. The DOS compatibility of Matrox cards isn't the best though. See here for more details: https://gona.mactar.hu/DOS_TESTS/
