First post, by Shponglefan
- l33t
I'm currently using a GeForce4 4200 Ti with a fanless Zalman heatsink. While it performs fine and it completely silent, the heatsink does take up a lot of space occupying an extra slot on either side of the card.
I'd like to replace this will a quiet solution that would only take up a single slot, at least for the front the card (the back I don't care about). This way it won't block a PCI slot.
The case I'm using (Fractal Design Define R5) does have an option for a 120mm or 140mm fan on the side panel above the slots. This would be in addition to the two 140mm intake fans and 140mm rear exhaust fan currently installed.
I'm not sure if a 140mm fan would push enough air, since it wouldn't be concentrated on the AGP slot specifically. Might it be better to have a smaller 80mm or 120mm fan more directly positioned over or behind the AGP card?
Any ideas for either heatsinks to use? Fan/heatsink combos? My goal is to keep the noise down, but the video card cool.
