best retro card for 233mmx
First post, by zmija1
hello ,i got old compaq deskpro 2000 with s3 graphic awe 64 edo ram etc, i want t upgrade some caed from that era
what is maximum card i can put in it
onlly pci slot
voddoo is not in option becouse are expensive can find easy ati rage others are dificcult to get like matrox
like vanta banshee also riva tnt2 but most are agp
and other question
what is maximum posiible pci can put in it
is it possible some hdmi card to work drom 2004
Reply 1 of 24, by mwdmeyer
A 3dfx Voodoo Banshee or Voodoo 3 would be great. A TNT2 M64 also works well.
But they are all a bit hard to find or expensive.
I'm not sure if this card would work, but looks like a good price https://www.ebay.com.au/itm/375510519301
Reply 2 of 24, by Namrok
The thing about a P233 is the CPU will enormous hamstring any video card you put in there. For example, I just found a benchmark where someone threw a TNT2 in a P233, benchmarked Quake 2, and actually got about the same or worse results than I get with my Riva 128 in mine.
You probably want to go with the oldest card you can find so the driver overhead is minimal. You'd be looking at Voodoo 1 or 2, Riva 128 or Riva TNT. Maybe a G200? Was there ever a PCI version of that?
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 3 of 24, by iraito
Matrox G200, voodoo 1, banshee and similar, i wouldn't go with more powerful stuff.
Namrok wrote on 2024-07-17, 12:40:
Yep, i have one of those.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 4 of 24, by DrAnthony
I think best is also a really relative term. I would start with something cheap and see how it fairs for your use case. I'll add in a Rage Pro or Rage 128 as additional early cards that might be a good, cheap option.
One sticking point here is that the early titles that this CPU will be best suited for tend to skew towards working best with Glide. This is where the Banshee starts making sense as while they are still 4-5 times more expensive than a typical Riva 128, they are "cheap" for 3DFX standards (the same applies to the Velocity which is a Voodoo 3 in everything but name and VRAM capacity).
Reply 5 of 24, by marxveix
ATi Rage Pro 8MB PCI is also ok choice, with older drivers you get 3DCIF support, 4MB versions are slower so i would get it with extra RAM module (4MB integrated + 4MB added). I have one original Rage Pro 4+4MB, just with AGP, that is also little faster than PCI version. Latest drivers for 3DCIF is 5.37.x/5.38.x and 5.40.0/5.40.1. Of course they are slower than Voodoo2 or TNT. Rage Pro is at the Voodoo1 level or little better and bit slower than intel 752 (i815 chipset). If you do not care about 3DCIF, then there are these Chinese Rage XL PCI cards that can be also used, but only with newer drivers.
I think Geforce2 MX PCI or Rage128/Rage128 Pro PCI would be nice choice for your P233 MMX.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 6 of 24, by Shagittarius
I hate rage pro due to its inability to filter alpha blended textures. Ugly.
Some other complaints from a review:
"Rage Pro has double the number of gradients over Rage II and it is enough to not be perceived at first look, but still is far from proper filtering. ATI dragged this filter into next gen Rage 128 as well and fortunately for them almost nobody noticed. Another complaint is about reduced amount of texture samples at smaller mip levels, this creates obvious shimmering. The amount is about the same as for Rage II, but this time is less expected since Rage Pro was supposed to have high quality texturing engine and "free" trilinear filter will not compensate for such deficiencies. Also, mip mapping in advanced games like Unreal is still doing wrong mip selections, so I disabled it again. At least sub-pixel accuracy was significantly improved but there are still some polygon gaps to be seen in few games. "
Reply 7 of 24, by zmija1
i found ati 7000 can it work on this old compaw motherboard
Reply 8 of 24, by The Serpent Rider
Radeon 7000 has performance issues with PMMX level of hardware.
Reply 9 of 24, by marxveix
Shagittarius wrote on 2024-07-17, 15:24:
ATi Rage XL (Rage3) has this: supports video and graphics alpha blending ARGB8888, is this the same thing that you talk about?
https://old.vgamuseum.info/images/stories/doc … tions_dec03.pdf
For sure Rage XL did get transparent textures bilinearly filtered with Rage Pro tehnology that original Rage Pro was not capable.
Reply 11 of 24, by marxveix
Radeon starts to shine with faster CPU, Rage128 Pro can be used better at lower/older PC parts, Rage OpenGL is not that fast as Geforce, but Rage128 Pro can handle 32bit well.
Reply 12 of 24, by Namrok
Truthfully, 3d gaming on a 233 MMX is a novelty at best. The more I think about it, and the more I reflect on what I've actually played on my own 233 MMX, I gave Quake 2 and Shogo the old college try at ~30 FPS, but I've mostly stuck with 2D games. DOS games like Doom, Heretic, and Master of Magic, or Windows games like Diablo, Deadlock, and StarCraft. Thinking of giving Might & Magic VI a spin soon, which only has a software renderer.
If cards are expensive, just prioritize good DOS compatibility and 2D image quality, I suspect you'll be spending most of your time there.
Reply 13 of 24, by dormcat
You could start with GPU Database at TechPowerUp, which has 92 GPU on PCI cards.
The "ultimate" NVIDIA and ATI cards in PCI were GeForce GT 430 and Radeon HD 5450, respectively, but I assume you would not use those 2010 vintage cards on a Pentium-MMX build where the CPU becomes the bottleneck and you need it to play late DOS and early Win9x games, something those two cards way too new for.
Therefore, you should set your limit to those with Win9x support, namely no later than GeForce 6 or Radeon R300. GeForce FX 5200 and Radeon 9100 were probably the best PCI cards you could acquire with Win9x support, but IMHO they were still too new for your Pentium-MMX.
So you have to look even further: GeForce2 MX 400, Radeon 7000, Matrox Millennium G450, S3 Savage4 (I wonder why TPU has no S3 card in their database), or Voodoo3. The final decision would depend on your personal need (namely which game you want to play), your budget limit, and the availability of those vintage cards.
UPDATE: While writing this reply I found a thread by many VOGONS veterans: Which PCI Graphics Card For Socket 7 430tx/hx Builds?
Reply 14 of 24, by The Serpent Rider
Here's how various PCI accelerators scale with Pentium Pro: Graphics card for Pentium Pro build (This should apply even better for Pentium MMX)
Here's my thread with GeForce 2 MX vs Voodoo 3 scaling (also Mystique, but it's absolute trash): Intel 430HX L2 256Kb VS Intel 430HX L2 512Kb VS Intel 430TX L2 512Kb - Motherboards comparison
Reply 15 of 24, by zmija1
so that is limit of 233mmx average 30 fps with every card ,i will paly most nfs 123 7000 is the esisest to get now for 10 buck maybe i can find vanta or tnt 2 other is rare
Reply 16 of 24, by DEAT
zmija1 wrote on 2024-07-17, 10:53:
You can find PCI Radeon 7000 cards with DVI output that will run fine on a 486 - but as The Serpent Rider said, the Win9x drivers aren't particularly well-optimised for a PMMX.
win16.page | Twitch
Reply 17 of 24, by The Serpent Rider
Also Pentium Pro benchmarks were done in 1024x768 resolution. Some cards like Savage 4 scale much better in lower resolutions, while Radeon 7000 does not. And even in 1024x768, when it dips - it dips hard (see Turok performance).
Reply 19 of 24, by 386SX
Rage Pro PCI, Riva 128 PCI, Voodoo 1 or Banshee.
