First post, by skafen
Hi All,
I have an Amaquest/Anson/Ansoon Technology Co. AP8548 Sis 496/7 PCI Socket 3 motherboard I acquired.
It works mostly (now) after fixing a few odd problems including dead RS232 line driver chips and ram sockets having gunk on them preventing simms from contacting correctly and at this moment is working quite well with an Intel P24C (writethough) Intel DX4 100 cpu... except for L2 Cache. It came with fake cache which I have removed and socketed but it does not work.
The board is listed on TRW https://theretroweb.com/motherboards/s/amaque … ology-co-ap8548 but seems to be an unknown with zero documentation on it.
I've figured out the CPU Voltage and FSB Speed jumpers and it came configured by the looks of it for an Intel 486DX. But the rest of the jumpers are a mystery including the L2 cache jumpers.
This is my third board of doing fake to real cache so am getting quite used to what to look for now but am a bit stumped on this one.
All cache sockets including the tag are getting normal looking signals on my oscilloscope compared to my last board I fixed which was a PCChips M912. It currently has a confirmed working 128K+Tag of 5 32kx8 15ns ISSI Chips and I cannot get it to recognise cache at all. The bios table says just WB under cache and speedsys/cache check etc all confirm no L2 cache.
Cache sizing appears to be done byJ14 and J15 which were pin-wired and I have replaced with headers and jumpers. Also it originally came with 4x passive resitor networks in U21/U22 which I have also now replaced with sockets and added 74F373N chips which also seem to have expected signals on them.
It's not the bios hobbled to disable cache as my M912 was. See PCChips M912 V1.7 Fake to Real Cache and new cache not recognised. I Suspect Bios version. for details on that as I've just tried the bios from a Jetway J446A on it which boots perfectly but says 256K no matter what.
I've got the Sis496/7 datasheet and am looking at that but it doesn't say how the L2 cache size detection actually works which would be useful to know at this point.
If anyone knows how this is done or has any info on this board at all I could really use the help with it.
Thanks
James
Reply 1 of 8, by skafen
Additional: I also added headers to JP10 and JP11 which are right behind the cache chips but trying diffrent configurations of jumpers there also either doesn't help or makes the board not post properly or at all.
Reply 2 of 8, by MikeSG
Assuming two TAGS, and one cache chip is right, there may be a third jumper in addition to J14, J15 to set.
Some of the other boards on retroweb with the same chipset have manuals, and have 3-4 jumper settings. The first two specify/multiplex 128, 256KB. The third specifies 512KB.
I would trace J32, to see if it is involved with the cache, and/or look for another solitary jumper.
Reply 3 of 8, by skafen
MikeSG,
Thanks for responding. Why do you say two TAGS? The board definately only has the one 28-pin tag socket plus the 4 32-pin cache sockets.
I understand what you say about having more than the two jumpers though, but in looking through docs it seems to me that that most boards with 1 bank of cache like this one only have two jumpers and the third jumper is usually on dual-bank boards so you can select 256k as 4x 64kx8 or 8x 32kx8. Unless I'm wrong there.
Reply 4 of 8, by MikeSG
Sorry I got mixed up about the two TAGs.
This board has four jumpers to select one bank (4x 32x8kb). https://theretroweb.com/motherboards/s/a-tren … -atc-1425a#docs
But the other Amaquest board (with manual) only has the two jumpers. Written on the board between first & second PCI slots. https://theretroweb.com/motherboard/image/ap8 … 73403689772.jpg
So the two jumpers may be right.
Reply 5 of 8, by skafen
J32 appears to also be a keyboard lock when shorted.
Reply 6 of 8, by skafen
Ah yes I see what you mean with the A-Trend board, I did think that the J10,J11 jumpers might serve that purpose but I've not been able to 'guess' any jumper config that works to get any cache at this point. I am looking at that other Amaquest board too, it looks like it could be an earlier predessor to this board, but the CPU slection jumpers are quite different sadly so not enough of a clue.
I've buzzed out the important pins on the cpu socket which vary between intel and cyrix and it looks like for intel writethrough none of them make any difference here. In fact the the board works including windows and PXE booting from a network card quite happily with only one single jumper present that is the voltdet pin. So I dont think the cpu selection jumpers here are what's upsetting the l2 cache here.
Reply 7 of 8, by MikeSG
You could try putting the resistor networks back (or jamming them in the sockets with the 74F373 chips to test). High speed signals often need pullups/downs.
Reply 8 of 8, by skafen
Already tried it. They fit find in the sockets on their own or as you say jamming in as well. Signals look okay. My scope isn't quick enough to show how clean the signals are at 33 or even 25mhz fsb but there's no obvious ringing or distortion of the waveforms.
