First post, by Linoleum
I am hoping to connect a sound blaster Live! to an Audigy 2 Front Panel Drive; most importantly, the headphone jack. The rest is not important (for now)...
I did the best I could to map as many connections as possible:
The attachment sblive-to-audigy2drive.jpg is no longer available
(see: https://docs.google.com/spreadsheets/d/1HxNqo … dit?usp=sharing)
As you can see, this is going to be a wiring sh*t show! So, I'd like to find the minimum connections required to have the headphones connection working...
Anyone has experienced this?
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 1 of 3, by darry
If you just want to use the I/O panel as a headphone DAC, you can do that much more simply.
See https://polprog.net/blog/audigy2zs/
If you want something likely better sounding (and measuring), easier to implement but a bit more costly, I suggest looking into something like an SMSL DS100 . If your card has noisy analogue out, but also has S/PDIF (coaxial or optical) digital out, cheap "OK" DACs exist
Full disclosure: I own several X-FI and Audigy 2 I/O panels and they all seem to have developped issues to some degree with either reliable detectability or audio or both when used with X-FI cards, which made me consider and buy the SMSL DS100. Though this is overkill for a Live! and its oddly non transparent digital I/O (even at 48KHz). For 44.1KHz content resampled to 48KHz by the Live! card's DSP, you can see how that measures here Re: Not so crazy idea : using a Raspberry Pi 4 with jackd , Zita A2J bridge and jack_mixer to make a software S/PDIF mix along with a comparison to a modern open-source realtime resampler implementation, if that is of interest to you.
EDIT: On the Amazon page for the DS100, there are some other measurement comparisons, if interested.
Reply 2 of 3, by Linoleum
Well, well, well... I found on DriverHeaven forum a thread dating from 2005 where username 10v3r posted a wiring diagram where he was connecting his Audigy 2ZS card to a Live! front panel (the reverse of what I am trying to do):
The attachment LiveToAudigy2_v2.jpg is no longer available
... and it works!! I will need to test all connections and report back. But, the headphone jack and volume knob do work!
Source:
https://web.archive.org/web/20090605235042/ht … html#post527070
PS2 30/286, SBP
Reply 3 of 3, by darry
Linoleum wrote on 2024-11-08, 01:46:
Well, well, well... I found on DriverHeaven forum a thread dating from 2005 where username 10v3r posted a wiring diagram where h […]
Source:
Next steps :
a) Design, build/test and "mass" produce a reversible interposer
b) sell and profit 😉
More seriously, I'm glad you got it to work with apparently full functionality.
EDIT: Oh, and if you intend to use this under DOS, especially with the few programs that natively support the Live! on that OS, keep in mind that not all the Live!'s S/PDIF ports are equal under DOS. For an example of the potential caveats, see Re: sblive dos digital output .
