First post, by sndwv
Hi,
I tried installing Indiana Jones and his Desktop Adventures from an imaged floppy with 'imgmount a [theimage] -t floppy' and initially didn't get it to work. After running SETUP.EXE from Windows 3.11 I get a "Can not find LZEXPAND.DLL" error, followed by a bunch of prompts about other files, and the setup program exits. This is with DOSBox SVN r4484.
Doing exactly the same with DOSBox Staging 0.82.0 however 'Just Works'.
What ALSO works in BOTH versions of DOSBox is copying all files from the imgmounted floppy to a folder (from within DOSBox even), mounting that folder with 'mount a [thefolder] -t floppy', and then running setup.
Is there a known issue with imgmounting floppies in DOSBox SVN? Am I doing something wrong with the command, omitting some parameter?
