First post, by InterClaw
This is probably a very easy question to answer.
Could 3.5" diskette drives run in parallel on the same channel in like in a master/slave configuration like IDE hard drives did? Or was it always separate channels, cables, and connectors on the motherboard if you wanted to have a B: drive?
Reply 1 of 9, by megatron-uk
Floppy disks (almost always) run on the same cable, with a twist in the cable being used to make one of the drives respond to drive b: compared to drive a: - this is why you (almost never) have to jumper a floppy drive as a: or b: ... it's the position on the cable which determines it:
133.62 KiB
Yes, there are exceptions, especially if using floppy drives not originally intended for PC use, but the above is true in 99% of cases, and it meant that manufacturers could send out their disk drives all jumpered/configured for drive a:.
https://www.target-earth.net
Reply 2 of 9, by InterClaw
megatron-uk wrote on 2025-01-10, 08:58:
133.62 KiB
Sweet, thank you! When I see the picture I do remember those cables now. 😀 Now I just gotta see if I still have one like that to try it out.
Do you also know if it's possible to run with just a B: drive, if you really wanted to?
Reply 5 of 9, by eisapc
The twist works together with the drives DS (drive select) Jumper wich can be set between 0 and 3.
Usually it is set to 1 , thats why you need the twist.
Setting it to 0 should eliminate the need for the twisted cable.
There were configurations with 2 devices on a single cable.
2 FDDs and a tape streamer.
No idea how these setups worked?
Reply 6 of 9, by Errius
3.5" drives are configured for B: by default if I remember correctly, but the twist at the end of the cable causes that drive to be seen as A:
Is this too much voodoo?
Reply 7 of 9, by megatron-uk
Errius wrote on 2025-01-10, 15:11:
I knew I'd have it the wrong way round! 😁
Reply 8 of 9, by BitWrangler
If you've got systems, which were mostly post-2000, that only had a single device cable, then check you can actually select a B drive in CMOS Setup, because some of them, managed to cripple things somehow so that only a single A drive works. Though how crippled is variable, sometimes they don't appear by default in DOS but windows can still pick a second drive up, or you can use it in linux. These are typically going to be P4 or AMD A64 class upwards.
Reply 9 of 9, by wierd_w
BitWrangler wrote on 2025-01-10, 16:40:
And surprisingly, you can often set the option ANYWAY with things like GSETUP.
I have a P4 era board that staunchly refuses to allow anything except 3.5" drives, and only for the A: slot.
I can forcibly set it for B, and set it to 5.25" types with gsetup, and they work just fine.
