First post, by clownwolf
UPDATE: Found a post by user gerwin from 2009 that actually has a list of chipsets I can use as data! I believe its a single chipset solution if the chip is listed as having Controller+Codec+OPL3 Clone Sound cards - from best to worst
Would any audiophiles/collectors be able to help me compile a list of single-chipset ISA sound cards? These are mostly used in budget cards, with Crystal's CX4235 and ESS' ES1868F being some of the most common examples.
I am hoping to get a definitive list as I start collecting them all. I pair these cards with GUS/PAS/Soundscape, so their FM synth performance is secondary and not a dealbreaker for me.
Analog Devices:
  • AD18max10JS - card model owned: 2x Digitan DSAC-300
  • AD1812JS - card model owned: 2x Action Well Development AA-1812
  • AD1815JS - card model owned: 1x [Unknown] AD15-3DS, 1x [Unknown] Audio-1815, 1x Action Well Development AA-1815B
  • AD1816JS - card model owned: 2x Acer FX-3D Rev. A
  • AD1816AJS - card model owned: 2x Acer FX-3D Plus
  • AD1821JS - card model owned: 1x Action Well Development AA-1816
Avance Logic:
  • ALS 120-based:
  • ALS100Plus+-based: Not a true single-chip solution. Uses an undisclosed OPL3 clone somewhere on the PCB (ex. LS262, disguised as LS245, DSP245)
  • ALS200-based: Not a true single-chip solution. Uses an undisclosed OPL3 clone somewhere on the PCB(ex. LS262, disguised as LS245, DSP245)
AZTech
  • AZT-2320 - card model owned: 1x AZTech Sound 16B SRS 3D, 1x AZTech Sound Galaxy Pro 16 III-PnP
  • AZF3318 - card model owned: 1x AZTech Multimedia PRO16V-3D
C-MEDIA
  • CMI8330 based:
    • CMI8330A/C3D Datasheet
      • CMI8330- card model owned: 1x [Unknown] Generic Card
      • CMI8330A - card model owned: 2x Audio Excel AV310
      • CMI8330A/3D
      • CMI8330C/C3D - card model owned: 1x [Unknown] Generic Card
      • HT1869V+ - card model owned: 1x Elpina Generic Card, 1x [Unknown] Generic Card
Creative:
  • CT2505 - card model owned: 3x Sound Blaster 16 Prelude CT2960
  • CT2508 - card model owned: 2x Sound Blaster Vibra 16 CT4100
  • CT2511 - card model owned: 2x Sound Blaster 16 WavEffects CT4170
  • CT8920 - card model owned: 1x Sound Blaster 16 WavEffects CT4525 *NOTE* might be considered a single-chip card based on your own definition/use-case. See discussions below.
Crystal:
  • CS4235 based:
    • CS4235-JQ/KQ Datasheet
      • CS4235-JQ - card model owned: 1x Pine Technology PT-2316-20 V3.0, 1x [Unknown] Generic Card
      • CS4235-KQ - card model owned: 1x [Unknown] Generic Card
      • CX4235-XQ3 - card model owned: 2x Pine Technology PT231X
      • CX4235-XQ3 EP - card model owned: 1x Pine Technology PT231X
    • CS4239-JQ/KQ Datasheet
      • CS4239-JQ
      • CS4239-KQ - card model owned: 1x Pine Technology PT2318-4 V2.0, 1x [Unknown] Generic Card
  • CS4236 based:
    • CS4236-KQ Datasheet
      • CS4236-KQ - card model owned: 2x [Unknown] JYS001 V1.1
      • CS4236-KQ EP - card model owned: 1x [Unknown] SM423X Rev 3.10
    • CS4236B-JQ/KQ Datasheet
      • CS4236B-JQ
      • CS4236B-KQ - card model owned: 1x Dictaphone Boomerang
      • CS4236B-XQ3 - card model owned: 1x Serenade SR-S161-F, 2x TYPHOON KJD-MUSIC16 (card can also be found with XQ3 EP Suffix)
      • CS4236B-XQ3 EP - card model owned: 2x TYPHOON KJD-MUSIC16
  • CS4237-based:
    • CS4237 (datasheet not available)
      • CS4237 (unconfimed)
    • CS4237B-JQ/KQ Datasheet
      • CS4237B-JQ
      • CS4237B-KQ - card model owned: 1x [Unknown] Music-16, 1x Tenda Generic Card
      • CX4237B-XQ3 - card model owned: 1x AOpen AW35 PRO, 1x [Unknown] FSSC-CS1.1
Diamond:
  • DT-0197H - card model owned: 2x Diamond Technologies DT197A30
  • DT-0297F - card model owned: 1x Diamond Technologies DT297A40
ESS:
  • ES1688-based
    • ES1688F Datasheet
      • ES1688F - card model owned: 1x Formosa Industrial SC1630, 1x MICRO EQUIPMENT CORPORATION UN-1688 ver. 1.5
  • ES1698-based
    • ES1698 (datasheet not available)
      • ES1698FC
  • ES1788-based
  • ES1868-based
    • ES1868 Datasheet
      • ES1868F - card model owned: 1x Formosa Industrial SC200, 1x Pine Technology SC1868-3D Rev. 1.10, 1x BEHAVIOR 1853L/1857L REV:B
  • ES1869-based
    • ES1869F/S Datasheet
      • ES1869F - card model owned: 1x LABWAY CORPORATION A111-A20, 1x Formosa Industrial SC202, 1x Compaq ES1869 Audio Feature Board
      • ES1869FC - card model owned: 1x [Unknown] ES186XM3 Rev 98, 1x [Unknown] 233X, , 1x [Unknown] Generic Card
      • ES1869S - card model owned: 1x [Unknown] Generic Card
  • ES1878-based
  • ES1879-based
  • ES1887-based
  • ES1888-based
Opti:
  • 82C931-based
    • 82C931 Data Book
      • 82C931 - card model owned: 1x DataExpert MED3931, 1x [Unknown] OP931-3DIS R0.1
  • 82C933-based
Rockwell
  • RWA010 - card model owned: 1x DCS S717
  • RWA011 (unconfimed)
Yamaha
  • OPL3-SA1 based:
    • YMF701-F/S Datasheet
      • YMF701-F (unconfimed)
      • YMF701-S (unconfimed)
      • YMF701B-S - card model owned: 1x Addonics Sound Vision 500
  • OPL3-SA2 based:
    • YMF711-S Datasheet
      • YMF711-S - (unconfimed)
      • YMF718-S - card model owned: 1x [Unknown] SM718 Rev 2.00, 1x [Unknown] UFC-101
  • OPL3-SA3 based:
    • YMF715-S Datasheet
      • YMF715-S (unconfimed)
      • YMF715B-S - card model owned: 1x Atrend ATC-6631 *NOTE* This card can have YMF719 chip instead
      • YMF719B-S - card model owned: 1x [Unknown] SM718 Rev 1.10, 1x [Unknown] SM718 Rev 3.00
    • YMF715E-S Datasheet
      • YMF715E-S - card model owned: 1x [Unknown] SM718 Rev 2.00
      • YMF719E-S - card model owned: 1x LABWAY CORPORATION A151-A00, 1x [Unknown] YAMAHA 3D SOUND CARD MS719
Reply 1 of 15, by bertrammatrix
Yamaha! You simply can't not have one of those!
I also have an Aztech azt2320 based card which I really like even though it's one of those cards that can be pretty finicky to get working right
Reply 2 of 15, by clownwolf
bertrammatrix wrote on 2025-04-22, 02:17:
Thanks! I totally forgot about Yamaha, I was way too focused on OPL3 emulation I forgot the original. After research via DosDays and Retroweb, it looks like 3 of their 5 single-chip solutions made it into actual ISA cards.
YMF701
YMF718
YMF719
For Aztech, I always thought they used multiple combinations of chips on their cards. But it looks like they made a single chip solution after all:
AZT-2320
Reply 3 of 15, by Dorunkāku
Some more obscure chipsets:
AZFIN AZF3318
Rockwell RWA010
Rockwell RWA011
With the difference being: the RWA010 supports 16-bit PnP address but not CD-ROM interface; RWA011 supports 12-bit PnP address and CD-ROM interface.
Reply 4 of 15, by clownwolf
Dorunkāku wrote on 2025-04-22, 04:15:
Some more obscure chipsets: AZFIN AZF3318 Rockwell RWA010 Rockwell RWA011 […]
AZFIN AZF3318
Rockwell RWA010
Rockwell RWA011
Thanks! I am going to put the AZFIN under AZTech. I actually found one for sale and bought it just now.
For the Rockwells, no info even on Retroweb. Thankfully there are threads here that has at least pics of them. I do hope they pop up again for sale in the future.
Reply 5 of 15, by zyga64
ALS100+ - not really All the truth about FM in ALS100 Plus+ cards (includes facts, tech info and tests)
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-3+@400 /64M /Rage Pro PCI /ES1370+YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 6 of 15, by clownwolf
zyga64 wrote on 2025-04-22, 07:18:
Huh. I just removed ALS200 from the list, and now it looks like ALS 100 plus+ uses disguised OPL3s as well?
That leaves ALS120 then. I looked at the pics and there really looks like one IC chip there.
Reply 7 of 15, by badmojo
clownwolf wrote on 2025-04-22, 01:17:
Yamaha YMF701 YMF718 YMF719 […]
Yamaha
YMF701
YMF718
YMF719
There's a YMF715 out there too and I'm pretty sure I've seen it on an ISA card.
Reply 8 of 15, by clownwolf
badmojo wrote on 2025-04-22, 08:04:
Yamaha
YMF701
YMF718
YMF719
Looks like A-Trend 6631 can potentially have YMF715. But all the pics show the cards using YMF719.
Although as per the table below from DosDays, they might be functionally equivalent anyway. Although cant be 100% sure since I cant find a datasheet for YM719.
The attachment Screenshot 2025-04-22 013538.png is no longer available
Reply 9 of 15, by Dorunkāku
The driver for the AZF3318 is a bit hard to find, so in case someone needs it:
Reply 10 of 15, by mkarcher
It's kind of stretching your definition, but possibly the CT8920 AWE64 chip on the CT4520 AWE 64 counts. The card is clearly not a single-chip solution, but the extra components are the EMU8011 wavetable ROM, a 512K x 16 wavetable waveform RAM and a 256K x 4 reverb/chorus buffer RAM. These components are required for the advanced music synthesis. An OPL3 repacement (Creative CQM), the SB16 controller, the DAC/ADC and the mixer are integrated in that chip. The LS245 on that card actually is a ISA data buffer and not a disguised pirate copy of the OPL3.
Reply 11 of 15, by clownwolf
Yamaha
YMF701
YMF718
YMF719
Found an actual YMF715 card
The attachment Screenshot 2025-04-22 090720.png is no longer available
mkarcher wrote on 2025-04-22, 09:38:
Thanks! I was going to take the lazy approach and just leave it out to keep the list simple. I can just add a note that this chipset was not released on sound card as a standalone chipset.
EDIT:
As per DOS Days, CT8920 was released on a cut-down version! So it was released without the synth!
Be warned there are some crippled versions with the same PCB wording "Model CT4520", but with most of the chips missing as well as the wavetable header. These were supposedly sold to OEMs (Dell or Packard-Bell perhaps), and effectively made these cards into a straight Sound Blaster 16. In the Creative Sound Blaster Products list, these are called CT4525.
Reply 12 of 15, by mkarcher
clownwolf wrote on 2025-04-22, 16:28:
... with most of the chips missing as well as the wavetable header. ..., these are called CT4525.
I just found a picture of a CT4525 on ebay. While it misses the wavetable ROM and wavetable sample RAM, as well as the headers for the RAM extension module (those are not waveblaster-like wave table headers, as the DOS Days quote seems to imply), that card still has the effects engine tank RAM. I'm currently not aware whether AWE64-type cards generally route the FM music through the EMU8000 engine, but it might very well be the case. This would make the CT4525 card a two-chip solution that has the extra capability of applying chorus/reverb to the CQM music, so not a true "single-chip" solution.
Reply 13 of 15, by clownwolf
mkarcher wrote on 2025-04-22, 18:28:
So the two chips are the CT8920 chip and the RAM on its left side? But if it the 2nd chip is just RAM, then I guess it depends on one's point of view if this can pass off as an integrated single-chip card.
Also, as a side note I bought the CT4525 card you mentioned, and also a rare Rockwell soundcard too.
Reply 14 of 15, by bertrammatrix
Found an actual YMF715 card […]
Yamaha
YMF701
YMF718
YMF719
EDIT:
I was looking for the "holy grail" of these YMF last year. I don't think there is any real difference between a 715, 718 or 719. The 715 seems the least common, and the 719 has the "spatializer" IC that is usually external (on the 715 and 718 -I think- ) built in. Since every sane person leaves the "y-immersion" off anyway you can consider all 3 equal
Reply 15 of 15, by Tiido
YMF701 - literally glued together OPL3, MPU401, SBpro2 and WSS. Non-PnP and resource hog since SB, WSS and MPU use 3x IRQs and WSS and SB use their own separate DMAs too.
YMF711 / 718 - PnP, with shared IRQs and DMAs between all the components, dramatically reducing resource requirements.
YMF715 / 719 - adds bass and treble controls and Ymersion aka Yamaha's take on the stereo field widening methods
YMF715B / 719B - adds Ymersion types and some low power support for laptop use
YMF715E / 719E / 741 - adds lower power modes and ability to read back multipurpose pins configuration mode. YMF741 reports itself as E revision, seems to be very uncommon.
YMF715F - I have only ever seen this one in a Toshiba laptop, appears functionally same as E but the laptop will not boot with other chip revisions so there are some secrets in it that are missing in others.
E revision seems to be the most common one
