First post, by ddoyle525
Hello, I recently purchased a new Edom/WinTech MV035F motherboard and I am able to run it with 64MB RAM, however the manual and specs state it can support 128MB RAM with two 72-pin 64MB 16M*36 memory modules.
So I purchased 2 72-pin modules from Memory Masters and installed them in Bank1 and Bank2 the when the system boots it counts 66MB RAM and stops counting and DOS loads but it is very unstable and crashes.
I tested each module individually with Speedsys and each one seems to be fine. When either one of these modules is installed in Bank1 the system counts 65535KB RAM.
Changing BIOS settings has not helped.
Also I know that the RAM slots work because to get 64MB RAM working I had to populate the 4x30-pin RAM slots with 4MB modules (16MB) and populate the remaining three 72-pin slots with 16MB RAM modules for a total of 64MB.
Note, all memory in the current config is single sided but the 72-pin 16*36 modules are double-sided.
Note, I tried to flash the BIOS but I get the dreaded error "The program file's part number does not match with your system!"
Any help or advice as to what to try next?
Specs: https://theretroweb.com/motherboards/s/edom-wintech-mv035f
"Jesus said to him, “I am the way, the truth, and the life. No one comes to the Father except through Me." - John 14:6
Reply 1 of 11, by jakethompson1
Many VLB boards do not have a Flash BIOS, rather, you purchase and program another BIOS chip using a hardware programmer and then swap it.
Reply 2 of 11, by Horun
Curious why you want to try and run 128Mb ram on a 486 board, max for true ms DOS is 64Mb iirc.
Reply 3 of 11, by ddoyle525
jakethompson1 wrote on 2025-04-26, 00:26:
Thank you for that information.
Reply 4 of 11, by ddoyle525
Horun wrote on 2025-04-26, 00:35:
Just wanted to max it out to see how far I can push it. I've installed Windows 2000 successfully with 64MB RAM.
Reply 5 of 11, by darry
ddoyle525 wrote on 2025-04-26, 06:35:
It might actually be slower with 128MB of RAM if the maximum cacheable range the chipset supports is significantly smaller than 128MB. No idea if this is the case here.
Reply 6 of 11, by Disruptor
darry wrote on 2025-04-26, 06:44:
Windows 2000?
When you can avoid paging, no.
But I use 256 MB of RAM in my 486. Maximum cacheable area with 1 MB in write-through mode.
Reply 7 of 11, by darry
Disruptor wrote on 2025-04-26, 16:04:
Windows 2000? When you can avoid paging, no. But I use 256 MB of RAM in my 486. Maximum cacheable area with 1 MB in write-throug […]
Windows 2000?
In the case of software that would otherwise need to use a swap file, more RAM is always better. But for most people here the primary use case for a 486 is not running something like Windows 2000. Making Windows 2000 faster at the expense of making practically everything else slower might not be optimal for running 486 era software under DOS (depending also on how significant the slowdown would be, of course).
If OP's board can cache all 128MB of its RAM, there would obviously be no issue.
Reply 8 of 11, by ddoyle525
I tried one last pair of 64MB Crucial modules and it still would not work, so I decided to just leave it at 64MB. Those same Crucial modules worked great in my EFA 4DMS-HL3G 486 mobo so that helps.
I appreciate all the assistance.
--David
Reply 9 of 11, by ddoyle525
Second update - I figured it out. I was able to get it to work with 128MB RAM with a Diamond Speedstar Pro SE card but on some games the graphics were glitchy.
So I tried a generic Cirrus GD-5428 VLB card and numerous graphics errors appeared - even the Energy Star logo was all messed up. So I removed the memory module in SIMM slot #2 and - success! No more glitches.
It turns out the issue is SIMM slot #2 is bad on this MOBO because regardless of what memory stick I use in that slot it always fails. However I can use either stick in SIMM #1 just fine, no errors.
I'll have to live with 64MB RAM instead of 128MB but that is more than enough for legacy OS's.
I'm not sure why some video cards were more forgiving, but I can consistently re-produce the error and resolution every time with this generig GD-5428 card.
Phew!
Reply 10 of 11, by Disruptor
Oh, well, it is VLB.
I remember I have at least one VLB graphics card which places its LFB at 64 MB.
So I'm unable to put more than 64 MB into this machine. I think the LFB was slightly below 64 MB, so the limit was somewhere at 48 or 56 MB. But I'm uncertain about this.
You may check the LFB address range of your VLB graphics cards.
And on some motherboards like my PVI 486 SP-3 I was not able to install both 128 MB modules. That board was limited to 192 (224) MB in fact.
Reply 11 of 11, by MikeSG
It may be a case that you need to add an extra DRAM wait state to run 128MB.
I have a 386DX board that runs 0WS at 12MB but needs a CAS wait to run 16MB.
