First post, by coxilerio
Hello i got a mb Mainboard that on pcb lists a numner only 35-8804 ans a pcpartner logo
on boot of bios i see this bios: bios-g (71209B)
and on bottom this string
01/22/98-580VPX-LGS3C-2A5LDV3HC-00
such version of bios is no where to be found even in retroweb , so even if i wanted to update the bios i cannot , as flashing different bioses on it will brick it completely and must be then garbaged !!!
can anyone help me out?
thanks
coxilerio
Daily drivers:
Gigabyte Z790 Aorus elite, Intel 12900KF, I-Chill X4 RTX 3090
ASUS B550F, Ryzen 7 5800X, Gamerock RTX 3070
Retro Builds:
Intel 440BX, Pentium 3 (500), Geforce 2 GTS , SB Audigy SB1394
Intel 440BX, Pentium 2 (400), 3dfx Voodoo 3 3000
Reply 1 of 8, by Repo Man11
I suspect that it is the original BIOS, which is often not listed with such old motherboards. From the listing on The RetroWeb, I see this note: "VT82C585VPX + VT82C586A on VIB804DS
VIB800DS/VIB804DS/VIB814DS share the same BIOS."
It does look as though you need to match the BIOS with the I/O chip your board has.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 2 of 8, by coxilerio
so motherboard is a VIB804DS or VIB804DSE ??? because they got different bioses... the screenshot is from VIB804DSE
Daily drivers:
Retro Builds:
Reply 3 of 8, by Horun
Need a good picture of the board to identify all parts. As Repo_Man11 said: you need to match the BIOS with the I/O chip your board has.
Curious why you want to update BIOS ? If the motherboard is working there is no need. There may not be a newer BIOS.....
Reply 4 of 8, by Mov AX, 0xDEAD
coxilerio wrote on 2025-05-24, 21:08:
Please upload unknow/uncollected BIOS to theretroweb.com
Reply 5 of 8, by coxilerio
Horun wrote on 2025-05-25, 05:00:
Because of this post
Re: Need HELP with socket 7 mainboard
But as said there as well,
i cant even run awdflash to try flash the bios
When typing on the keyboard in dos mode for gods sake the pc locks up and it must be reset...
Daily drivers:
Retro Builds:
Reply 6 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Please do not shout in the forum posts. It is generally considered shouting and rude to post in all caps. And please stick to one topic, one might argue that this is belongs to your other thread.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 8, by oh2ftu
Bad caps perhaps?
Reply 8 of 8, by coxilerio
Bad motherboard altogether i think
Daily drivers:
Retro Builds:
