First post, by zuldan
- Oldbie
I got this board for a descent price. It was sold as "For parts". I removed all the jumpers / cache / BIOS and gave it a good clean in some soapy water. To my surprise it posted first time. I can run Speedsys, Quake demo etc.
The current issues are;
(Not sure what else to do to diagnose the issues)
Issue 1 - When it first POSTs I get error code 07. The Award description is "Verifies CMOS is Working Correctly, Detects Bad Battery". If I turn off the PSU and switch it back on again within 1 second, the board POSTs perfectly.
The board came with BIOS version "01/11/95-SIS-85C471-I486SV2G-00" 0305. I've flashed it to "11/03/95-SIS-85C471-I486SV2G-00" 0402 but no change.
JP1 jumper was missing, so I thought that was the issue. I set the jumper to 1-2 (internal battery), but no change. I then configured the jumper to 2-3 (and installed an external battery). The 07 post code disappeared for about 30 minutes but then it came back and the situation got worse, it stayed on 07. The quick power off and power on trick didn't let me continue past 07. I disconnected everything from the motherboard, left it for 15 min and now the switch off/on is working again to get past 07.
Issue 2 - During the boot process it stops at the BIOS screen and prompts for F1 to continue but doesn't actually say what it's stopping for. If I change the "Halt on error" option to the BIOS to none, then this prompt disappears.
The band aid works fine, I just like to know what the error is.
Issue 3 - Won't boot from a SDCard when configured to use AMD P75 133 (booting to the SDCard works perfectly with a Intel DX2 66 Overdrive)
No idea what this could but haven't investigated it all since I'm still working on Issue 1.
