First post, by Shaknunic
- Newbie
This is the second post about Teamspeak in old computers, I honestly wanted to edit the entire stuff I did in my previous post, but I couldn't ,then I guess it was the best to delete the old one and make a new post improving the amount of details I did previously.
First of all this project was made with passion for old retro PCs prior to Windows 98 and XP, to easily serve to communicate and share what people wants at most. Keep in mind, if you want of course, you don't need to be dependent from the server mentioned and instead you can host an independent server yourself and share your own things. But I want to provide a server for everyone to join and be a HUB of people that own Retro PCs to connect and discuss about. Both servers majority of the times are empty and not a lot of people join in, so you can easily join with a friend and having a good time over there, no matter the country you're from. The server was designed to be compatible with old PCs, but it doesn't mean it can only be used to connect old machines, both TS3 and TS2 can run in modern Windows and Linux as well.
In order to make it work and to be compatible with the machines mentioned, the server needed to be run in an older version for both server and client. Although there's no harm for the user be running an older version, I just have to ask to please, if you want to exploit the server or try a DDOS attack, do that to the official Teamspeak 3 servers instead. The server was made to easily connect PCs over the world and also to facilitate communication between old retro gamers, so if you want to target people, it would be more worth it doing in those servers instead, believe me...
I'm also archiving a lot of Teamspeak 3 customization things such as: skins, soundpacks, overlays and etc (more than 400 customizations were archived already). These can be used in any Teamspeak 3 version. For plugins only certain TS3 versions are accepted to use it, but everything is in a specific order to make sure you're downloading the compatible version for your client. To access these files you need to be a "Regular" user in the server, in order words you need to actively join the server from time to time and then you will become a regular user in no time. More customizations and plugins can be added monthly, so if you have any suggestions contact the staff of the server. The customization items are getting stored in the "Shu - Dev/Owner" channel.
I'm archiving SDKs and developer tools to integrate Teamspeak on Unreal engine, Unity and create your own plugins and skins. Again, you need to be a "regular" user in order to access these files. But they are also available to download, meaning you still can integrate your homebrew apps or make a skin for an older version of Teamspeak 3 in mind, which in my opinion can be pretty cool and I support the idea for it.
The server I'm providing doesn't use any method to bypass slots. Yes the default TS3 without a license is limited to 32 slots and there's nothing you can do about it since Teamspeak as a company doesn't provide or support old licenses to buy, therefore, if you see an older version of the server like "3.0.13.8" and below out there, and the server have more than 32 slots, It's using a hacked license and you should NOT engage with the server because the intention of the owner could be malicious. The right thing to do is report the server to support@teamspeak.com instead (Yes! In 2025 they still receive reports).
The server in this post complies with the Teamspeak license, so even they can't take it down if you are using the server legally and responsibly.
Note: Because the server requires an older version of the client, this Teamspeak 3 version is incompatible with the latest Teamspeak 3, 5 and 6 versions. If you try to connect using any latest version, it won't allow you to join in!
If you want to talk with me directly you can either connect into one of these old servers or join my TS6 server typing 'Retros' in search bar on TS6 or in the address field on TS3.
Main features of Teamspeak 3:
- Crystal clear technology
- Voice encryption
- Can be used in a range of PCs
- Many old and new codecs available to choose.
- Support a bunch of languages
- Offline messages (Receiving while not in a server)
- Text messages
- Support for plugins, skins, soundpacks and etc
- Files can be sharable between users
+ Requires a SSE2 instruction processor
+ Requires at least 1gb of RAM
+ Compatible with both 32 and 64 bit.
Latest version is 3.0.19.4.
Latest version is 3.1.5.
Latest version is 3.1.10 [Only version compatible with Windows 11]
> Any Linux distro.
> Close to OS X 10.6 or later.
> Android 2.3.3 or later.
> iOS 6.1 or later.
> Both require versions between 3.0.19.3 to 3.1.9.
- For Windows XP and Windows Vista clients (3.0.18.2 to 3.1.5) use the address below:
retropcgaming.duckdns.org
- For any version after 3.1.6 (Windows 7 versions), use the Server Nickname below:
Windows 7
These Hashes are the official ones published officially!
TeamSpeak3-Client-linux_amd64-3.0.18.2.run
SHA-1: c5c8096e87314f786ba831782f077db7706c275a
TeamSpeak3-Client-linux_x86-3.0.18.2.run
SHA-1: e7a6fb23043de2715517f072706d50a25e2c7cfe
TeamSpeak3-Client-macosx-3.0.18.2.dmg
SHA-1: fc6c2948f1e2ff56b27305dd763a2aa4ff314880
TeamSpeak3-Client-win32-3.0.18.2.exe
SHA-1: 2f7c7991483aa0fbf4e6b5c07502cd85950e0472
TeamSpeak3-Client-win64-3.0.18.2.exe
SHA-1: 88aa7ce1258c21f2364043a9bb9e7f643482dd73
! Further hardened security fix from 3.0.18.1. Remote images are now stored in
single directory by hash, instead of subfolders.
+ Added external link warning to opening URLs from within URL Catcher
* Updated include folders in plugin SDK for recent code restructuring
* On entering an unsubscribed channel, scan all clients for CLIENT_TALK_REQUEST
and preset that value to avoid getting the notification sound when clicking
on that client later.
- Fixed unclickable Download Folder label in Filebrowser dialog.
- Fixed PTT delay not getting properly saved and restored.
- Replaced wrong clear filter icon in permissions overview dialog.
TeamSpeak3-Client-linux_amd64-3.0.19.run
SHA-1: cc6eefeb618efbb1e24128ff6449655f375a5db6
TeamSpeak3-Client-linux_x86-3.0.19.run
SHA-1: d90fa1ed202f4b4d2b6a4728f8184a96afaa3b17
TeamSpeak3-Client-macosx-3.0.19.dmg
SHA-1: ae7cda47f93278fcf4f314f3ce75f58ff4c40f6d
TeamSpeak3-Client-win32-3.0.19.exe
SHA-1: 640746b11d889497a521fcba9bbdd225d40800c3
TeamSpeak3-Client-win64-3.0.19.exe
SHA-1: b39619f540eac08e92e4aa29e68c4941cb5574e0
+ Added pre- and postinstall conditions to Updater to allow running custom
commands before or after an update. Will be used to install the new
Visual Studio 2015 C++ runtime for next release.
+ Added French and Spanish translations
* OS X client now uses Apple Transport Security instead of OpenSSL
* Updated Lua runtime in Lua plugin
* New features window now has an expire timeout to prevent opening outdated
news when doing a fresh install.
- Fixed possible crash on Linux 64-bit when receiving invalid network packages
- Fixed banners send with "Cache-Control" HTTP resonse header
- Fixed slow loading banners being shown after disconnecting from server
- Fixed possible freeze when loading lots of channel images
- Updated included libpng
- Updated included openssl
- Fixed master volume slider not updating properly when using multiple playback
profiles
- Prevent displaying locale images in bbCode IMG tags
- Don't collect channelid:// URLs in Url catcher
- Fixed freeze with many images in channel description
- Fixed ban presets showing invalid preset items
- Fixed avatar display when uploading a new avatar with different dimensions
- Fixed external links in About / License
- Fixed possible Qt crash when downloading from Http sources
- Removed server IP display in server and client connection info dialogs
- Removed setup wizard, replaced with a simple dialog to let users enter a
default nickname. To be expanded in a future release.
- Fixes to hotkey events in plugin SDK
TeamSpeak3-Client-linux_amd64-3.0.19.1.run
SHA-1: 738dc8596e5b6831395b320082c23ee3be29c9a8
TeamSpeak3-Client-linux_x86-3.0.19.1.run
SHA-1: 13e2c496e8d26f7d8603917d56e66459ef15e92b
TeamSpeak3-Client-macosx-3.0.19.1.dmg
SHA-1: 6be098b9da7e9931cbd9a307bf9c9d65f7122980
TeamSpeak3-Client-win32-3.0.19.1.exe
SHA-1: 93c34e6e9da29f8d3664796d0075a9d771ca33bb
TeamSpeak3-Client-win64-3.0.19.1.exe
SHA-1: dc6c270e7c6ef07be78f247f81795fd45e110953
+ Added polish and portugese translations
+ Added support for graylisted servers
- Fixed possible crash on weird unicode characters
TeamSpeak3-Client-linux_amd64-3.0.19.2.run
SHA-1: 08b6537a689136904fd4c08e0393748ce55f5a72
TeamSpeak3-Client-linux_x86-3.0.19.2.run
SHA-1: 045f19d44978fb5b754fa5839cf8b4e9b97210d4
TeamSpeak3-Client-macosx-3.0.19.2.dmg
SHA-1: 17fec0c0b99f0417a3a2c6891667ca7ac987a613
TeamSpeak3-Client-win32-3.0.19.2.exe
SHA-1: 3b1a9fabde486368c31aebdcf802ad1c263bc068
TeamSpeak3-Client-win64-3.0.19.2.exe
SHA-1: 150445a1472efe8737e98959bbe4ff9724a87bdf
- Fixed infinite loop when clicking on malicious channels/clients/server items
in the tree
- Updated polish translation
TeamSpeak3-Client-linux_amd64-3.0.19.3.run
SHA-1: af18747b40141f92b62d8176880c1b9a2c441265
TeamSpeak3-Client-linux_x86-3.0.19.3.run
SHA-1: dc88607726c26cda7e13bf078b664c3669b07c37
TeamSpeak3-Client-macosx-3.0.19.3.dmg
SHA-1: 7a200238b667a2acdcec852e327a9b4a8ec9d2c1
TeamSpeak3-Client-win32-3.0.19.3.exe
SHA-1: 086b5b8eed07b59341cafa4c9e61c5990b5942b7
TeamSpeak3-Client-win64-3.0.19.3.exe
SHA-1: 8925aa7e88bdb3a39d2d553909293e1a8275c0c5
- Another fix for client freeze on malicious input
TeamSpeak3-Client-linux_amd64-3.0.19.4.run
SHA-1: 87ab161865e9ba694e4862a81a9d06f6c5a7ed3b
TeamSpeak3-Client-linux_x86-3.0.19.4.run
SHA-1: 87dc6583a8ff0aba0844ae1eb72a9ebb89dc9a20
TeamSpeak3-Client-macosx-3.0.19.4.dmg
SHA-1: 6a8867b546dd9d5a2de075210ff9f7ec5b59d124
TeamSpeak3-Client-win32-3.0.19.4.exe
SHA-1: b8534eb206dbaf595ef0c2bfa5f97048fde259f4
TeamSpeak3-Client-win64-3.0.19.4.exe
SHA-1: 133aa532bf8e1d37ce4ad45dfb08da3ce18dc3ce
! Last release supporting Windows XP.
* Overwolf rebranding, open Overwolf webpage instead of running the installer.
TeamSpeak3-Client-linux_amd64-3.1.0.1.run
SHA-1: 1de01d1e4f4853db34af037d04bc9069dbb185ac
TeamSpeak3-Client-linux_x86-3.1.0.1.run
SHA-1: 8d5064b293a70df1eb81c9474456d0b13dea9f77
TeamSpeak3-Client-macosx-3.1.0.1.dmg
SHA-1: 9ab61acc04c51f590fac5cfe64043ac04a826c22
TeamSpeak3-Client-win32-3.1.0.1.exe
SHA-1: 28d0a1000881010a99bdb9d0e0d3a28f4857ff57
TeamSpeak3-Client-win64-3.1.0.1.exe
SHA-1: b83fcbfa528ceaa83f518716242fbdabe180897b
! Fixed crash at startup on Windows Vista
TeamSpeak3-Client-linux_amd64-3.1.1.run
SHA-1: 87fbd3d6156d40cd792e95ad432263037f4208fd
TeamSpeak3-Client-linux_x86-3.1.1.run
SHA-1: bfb7d8e722c8641f61b327ac02d85b6350387323
TeamSpeak3-Client-macosx-3.1.1.dmg
SHA-1: c7c40467aee7ad64d9239821608ec7d477c7dfeb
TeamSpeak3-Client-win32-3.1.1.exe
SHA-1: bc5e5a67a9d6d40699300e6c60274fc52cbfb858
TeamSpeak3-Client-win64-3.1.1.exe
SHA-1: 2c558ceec66059c86a81dcdd197c1149681117d1
! Plugin API version updated to 22. Version 21 plugins will continue to work.
+ New hotkey backend
+ New Plugin API to allow plugins to "provide" new hotkey input
+ Mouse Button 4 and 5 support on Linux
+ Improved cross-platform keyboard key mapping to better handle keys
on non US keyboards
- Fixed a bug that would cause the client to lose the ability
to handle hotkeys on Mac after an update using the built-in updater
! Hotkeys created using Client 3.1.1 are not compatible with 3.1.0.1 or below
! Moved Gamepad and Joystick support from the client to a plugin. This plugin
is available in myTeamSpeak and will be automatically installed.
+ Improvements to Windows Audio Session sound backend
* Added some informative tooltips and dialogs to myTeamSpeak dialogs, trying to
explain what "Stay logged in on this computer" and "Synchronization" features
do, as this apparently caused some user confusion.
* Changed behavior in myTeamSpeak options page. Apply settings immediately
instead of waiting for Apply/Ok click.
* Added openglblacklist.json trying to workaround broken OpenGL drivers of
some graphic cards, forcing software renderer mode.
* Added help texts to sync item collision dialogs to explain how a collision
happened and how to resolve it.
- TSDNS fixes to workaround issues with broken routers. Using Google DNS
servers as fallback.
- Fixed channel subscriptions of non-existant channels bloating bookmark sync
data. Bookmarks will auto-cleanup themselves on connect.
- Open external links in online addons browser widget in external browser.
- Limit channel auto-subscription to 500 channels to avoid exceeding maximum
server packet size.
- Fixed filetransfer from password-protected channels.
- Fixed updater UAC detection on Windows.
- Treat empty profiles in plugin API guiConnect function as "use default
profiles", fixing issue in Overwolf apps.
- Reimplemented plugin API call getBookmarkList, added demo code to test plugin
- Fixed crash in plugin API sendFile function when passing a nullptr as return
code.
- Fixed opening the recovery key dialog from statusbar icon when sync data
failed to decrypt.
- Increased settings.db version to 7 due to new hotkey backend.
- Fixed various crashes found through the crashdump upload system.
- Fixed third icon in badges setup dialog not showing the proper badge.
- Various fixes to importing pre-3.1 hotkeys.
- Fixed certain unicode characters in bookmark nickname to trigger the "unsaved
changes" dialog even if there was no change. Closing the bookmarks dialog
with "Ok" once will fix existing bookmarks.
- Fixed clearing cache during a running client session breaking badges.
- Fixed server- and clientlog filter list breaking on entries including
linebreaks.
- Fixed port being ignored in bookmarks using IPv6 addresses.
- Added "Cancel" button to myTeamSpeak account setup dialog.
- Fixed pressing escape not deleting the key in a hotkey dialog created by
the plugin API requestHotkeyDialog.
- Fixed a crash in the ClientQuery Plugin.
- When a style is uninstalled, the client now switches back to default.
- When a soundpack is uninstalled, the combobox for selection is now updated
properly.
- Sound packs can now use relative paths again to reference to default sound
pack files
- Default sound pack gets updated immediately upon installation through addon
browser.
- Addons are now sorted by name in the addon options.
TeamSpeak3-Client-linux_amd64-3.1.1.1.run
SHA-1: 0eff688daf0f5a8e5ecb409012a59104149c41a2
TeamSpeak3-Client-linux_x86-3.1.1.1.run
SHA-1: ae9e892e3753961e16428d103c10709dfa68a14e
TeamSpeak3-Client-macosx-3.1.1.1.dmg
SHA-1: 21c964778705b4b0a1a2313ff3a8e4b6280e67b1
TeamSpeak3-Client-win32-3.1.1.1.exe
SHA-1: 0d53098444563df1f1ab4892e2b3ba52dbf1a710
TeamSpeak3-Client-win64-3.1.1.1.exe
SHA-1: 200d81b8e41c1318d6a925a8edc0be4d43d3dd82
! Fixed possible crash on OS X
TeamSpeak3-Client-linux_amd64-3.1.2.run
SHA-1: bb7a306e0ed4cd64b2eae5a91ef2aa090f7a5d5b
TeamSpeak3-Client-linux_x86-3.1.2.run
SHA-1: 72b9604853bcd837659210d70d3257f5711a35a6
TeamSpeak3-Client-macosx-3.1.2.dmg
SHA-1: 4fc466523fcd7cc090bb0722f08c49018cc62905
TeamSpeak3-Client-win32-3.1.2.exe
SHA-1: d1891431b833ec7c8acd549959c0095a6aebbb56
TeamSpeak3-Client-win64-3.1.2.exe
SHA-1: b4afefafc069d16ca6ba0b3455b69595918e1e23
+ Added new hotkey setting to use this hotkey only in the current server tab.
* (experimental) added command line arguments to let users with broken gfx
drivers force using Angle DirectX backend or software rendering:
--force-opengl-angle --force-opengl-soft
* Control plugin is now managed by the online addon system
* Various improvements to Overwolf integration.
* Minor update to license agreement logic to avoid showing a new license text
when users are not required to re-accept the license.
* Windows Audio Session (WASAPI) sound backend improvements.
* Readded possibility to use ts3server links with token and addbookmark
parameters, which got lost with sync changes in 3.1. Instead of storing a
token in the bookmark as pre-3.1, the token is locally stored in a file
and used the first time a connection is established via the added bookmark.
Such tokens will not be synchronized via myTeamSpeak.
- Improved text in error reporter to make more clear what we are going to
upload.
- Updated some permission help texts
- Fixed incorrect channel password being used on automatic reconnect.
- Fixed bookmarks manager drag&drop where autoconnect bookmarks lost their
bold state.
- Fixed order of autoconnect bookmarks to behave again like in pre-3.1 clients
- Fixed package installer failing on package.ini files encoded with UTF-8-BOM.
- TSDNS deprecated dialog is now a message in the server tab.
- Fixes to sync status display in statusbar.
- Minor fixes to myTeamSpeak recovery key behaviour, don't allow using a
recovery key after logging out of myTeamSpeak account.
- Fixed myTeamSpeak item collision dialog to no longer try to solve a
collision while the item has already been deleted.
- Multiple improvements and fixes to new hotkey backend introduced in 3.1.1
- Minor fixes to file browser introduced with recent filetransfer rewrite.
TeamSpeak3-Client-linux_amd64-3.1.3.run
SHA-1: 7fdac5d6aba727829ca39318e9e46e3d90139cfb
TeamSpeak3-Client-linux_x86-3.1.3.run
SHA-1: fdaac74402315bba8d985c54204c11b666617c76
TeamSpeak3-Client-macosx-3.1.3.dmg
SHA-1: fd7309c2ac1e771f2379752e7fe56841aea6f4c8
TeamSpeak3-Client-win32-3.1.3.exe
SHA-1: 90781283306744e63349fcab3ca65cb0d5464a4f
TeamSpeak3-Client-win64-3.1.3.exe
SHA-1: 9a58196e4ce5adfbeecfd36650b011bdf2b63db4
* ClientQuery plugin is now managed by the online addon system
- Fix several hotkeys not binding properly
- Fixed rare crash in Windows Audio backend
- Fixed rare crash on exit.
TeamSpeak3-Client-linux_amd64-3.1.4.run
SHA-1: 646b58840f0c7f0622105a50724ce1b3a43d4e37
TeamSpeak3-Client-linux_x86-3.1.4.run
SHA-1: 609b251b57089ead592656588d50ca895cafae25
TeamSpeak3-Client-macosx-3.1.4.dmg
SHA-1: 26c434b1e4b41b09a0558b294ea2a288e83fa568
TeamSpeak3-Client-win32-3.1.4.exe
SHA-1: 5eb56b207fde94ecf6fc917e1d7fe0036c7bece9
TeamSpeak3-Client-win64-3.1.4.exe
SHA-1: c3a004ca63f94e011a981a2102a572313a61765b
+ Angle is now the default OpenGL renderer to workaround issues with the latest
NVidia driver update.
+ Added new commandline parameter --force-opengl-desktop, which would force the
old default renderer
- Fixes to recently overhauled windows soundbackend.
TeamSpeak3-Client-linux_amd64-3.1.4.2.run
SHA-1: d950a788ff1b14c585e1f9ab38f1eed3054f80ab
TeamSpeak3-Client-linux_x86-3.1.4.2.run
SHA-1: 823385e72fc3c8d04e6e221763258ad902dfdf27
TeamSpeak3-Client-macosx-3.1.4.2.dmg
SHA-1: 941c3562cc3cf06f5f164bf47a89730c6118caef
TeamSpeak3-Client-win32-3.1.4.2.exe
SHA-1: fa6201f88f78080fe4e7c6f74d5671ce000b9aeb
TeamSpeak3-Client-win64-3.1.4.2.exe
SHA-1: c12ea86a99bdc40bdc9609423979ea8fa79fb639
! This is the last release with support for Windows Vista
! Preparation release for 3.1.5:
Fixed possible issue when updating to future client release 3.1.5 would abort
with a timeout error when downloading and installing the Microsoft
redistributable installer for MSVC 2015 Update 3.
- Fixed package installer crash on Windows 32-bit OS.
TeamSpeak3-Client-linux_amd64-3.1.5.run
SHA-1: 922bccbd90b7712e077e56db62f3afa3f011deb0
TeamSpeak3-Client-linux_x86-3.1.5.run
SHA-1: 37e4d6883c19c658918ff93aa2c30738cf39b003
TeamSpeak3-Client-macosx-3.1.5.dmg
SHA-1: 4a572a268e53a738857b0497dd45f6b29c14990a
TeamSpeak3-Client-win32-3.1.5.exe
SHA-1: c9aacf92c594dff5cbfd8dcb6912195bc8b7cf0e
TeamSpeak3-Client-win64-3.1.5.exe
SHA-1: bb5a7a396f0f57514a7283cd774ac8682c18810f
+ Added possibility to overwrite Qt style icons with custom iconpacks
+ Added tooltips over client and channel items in server tree
+ Added support for SVG Tiny 1.2 (static only, no animations) icons. Most
icons are no longer hardcoded to fixed size 16x16.
+ Replaced included default_mono and default_colored iconpacks with SVG icons.
Iconpacks with PNG icons are still supported, so existing third-party
iconpacks continue to work. We encourage third-party iconpack authors to
update their iconpacks with SVG icons.
+ Overhauled icons in most windows for improved support for high dpi monitors.
* Updated Qt to 5.6.2 on Windows and macOS
* Updated Visual Studio C++ runtime on Windows to 14.0.24215 (MSVC 2015-3)
* New default style for infoframe based on "Improved Default" by Sven Paulsen.
* Removed old default/modern/classic styles.
* Rewrote translation mechanism for infoframe styles. Translations now come
from lagos_xx.qm and are filled by C++, so multiple language templates are
no longer necessary. However, for legacy style support, language templates
will be loaded with priority. So if e.g. clientinfo_de.tpl exists, it will
be used. If not, clientinfo.tpl is loaded, which should contain the new
translatable placeholders.
* Updater no longer downloads banner from server, banner is now hardcoded in
executable. Dynamic banners currently not needed.
- Addon management UI now properly shows state when plugins failed to
initialize.
- Multiple minor fixes to recently overhauled hotkey system
- Fixed infinite password dialog in file browser when using cancel
- Multiple minor filetransfer fixes
- Uninstaller now automatically closes the client instead of showing dialog.
- Fixed some wrong icon names in default iconpacks, which caused these icons
to be loaded from fallback default.zip.
- Automatically clean null icons from icon cache when updating from 3.1.4
to 3.1.5 client. 3.1.4 might have downloaded SVGs which it cannot use, which
caused creation of an empty icon file.
- Fixed length check in various nickname input fields. Trim whitespaces before
calculating length when doing validity checks.
- Added bandaids for misbehaving audio drivers on Windows
- Fixed possible Windows soundbackend crash reported by crashdumps
- Fixed possible spontaneous crash during client runtime.
TeamSpeak3-Client-linux_amd64-3.1.6.run
SHA-1: dc42632810f65d692803738d2ad429c2c1bc5b15
TeamSpeak3-Client-linux_x86-3.1.6.run
SHA-1: da89b578796fd76389a165c57306c73a1c8e25f6
TeamSpeak3-Client-macosx-3.1.6.dmg
SHA-1: 1826045becdab9abe7ecac3858da32388da20219
TeamSpeak3-Client-win32-3.1.6.exe
SHA-1: 66acc15441afc00339f184616827a9d7f76fdddf
TeamSpeak3-Client-win64-3.1.6.exe
SHA-1: 3d1fef8a83bb9d0724740c134de947976a3efcad
! Added Server Nicknames feature. Register a server nickname on the
myTeamSpeak.com webpage to let users easily connect to your TS3 server.
! Added support for new server property and permission, which allows you to
enter registered server nicknames as server property to display it to all
users on this server.
* Support for new black/graylist backend.
* Support for new server license features.
* Don't spam "failed to connect to myteamspeak server" notifications. Show
it once after client start and then again only in intervals of 6 hours.
- Windows sound backend overhaul continued.
- Fixed crashes reported by crashdumps.
TeamSpeak3-Client-linux_amd64-3.1.7.run
SHA-1: a49de8e3bbdc0a648724edb52296469137c7a6aa
TeamSpeak3-Client-linux_x86-3.1.7.run
SHA-1: 3956988804c5bc89a442517ba53b62e77e96d742
TeamSpeak3-Client-macosx-3.1.7.dmg
SHA-1: 1fec6e663f03d48c516e5f9244d251eea874ad82
TeamSpeak3-Client-win32-3.1.7.exe
SHA-1: 47902894ebdc688e3b0f8c7e31f786ac85d0dc7b
TeamSpeak3-Client-win64-3.1.7.exe
SHA-1: 7651c5c78a1e4fb0502fe2808e25797e4490b146
* Added setting in Options/Design to disable tree tooltips as requested by user
feedback. Tooltips are enabled by default.
* Added contextmenu to move bookmarks and identities between synchronized and
local lists as usability improvement for sight-impaired users.
* Updated license agreement in installers.
* Various internal changes for our new server accounting system.
* Added support for percent-encoded server nicknames in ts3server:// links,
invite dialog and chat.
* Use more reliable timestamp server for Windows code signing certificate.
* Refactored server nickname check and discard/apply behaviour in virtual
server edit dialog.
* Overhauled TSDNS code to better integrate new server nicknames into the
existing resolve process.
- Fixed rare possibility to lose synchronized items when myTeamSpeak server
gets unresponsive.
- Fixed subscribe mode producing errors when connecting to servers where your
subscription abilities are limited by permissions.
- Fixed empty license text in about dialog for non-german/english languages.
- Fixed possible rare crash when exiting the application on all platforms.
- Fixed possible crash on macOS in hotkey detection code.
- Fixed client freeze when trying to resolve a server nickname and backend
is unavailable or slow.
- Fixed crash in bookmarks dialog found in crashdumps.
TeamSpeak3-Client-linux_amd64-3.1.8.run
SHA-1: 74edefc38dfb8b9fd4d926e051b6bf6759d766b5
TeamSpeak3-Client-linux_x86-3.1.8.run
SHA-1: 2e9f4b6ee802b55b323cb54b7af1477411ffb668
TeamSpeak3-Client-macosx-3.1.8.dmg
SHA-1: 1883bf1b524f6f4441ce421583bbae0a54689ff7
TeamSpeak3-Client-win32-3.1.8.exe
SHA-1: d33e10f26a0d8feb008f9fda5a7056d51dddee72
TeamSpeak3-Client-win64-3.1.8.exe
SHA-1: ef571466d9bc89c81226fe2b114af47768c955f4
- Fixed disconnect on invalid connection info data.
- Fixed macOS application bundle which caused the client to not start on
case-sensitive file systems.
- Hardened Linux startscript to better find installed SSL certificates. If no
SSL certificates are found, don't crash the client on start but show
meaningful error message (but we still cannot run without SSL certificates).
- Fixed critical messagebox very early in the startup process, which tried to
load an icon before the zip archive was initialized.
- Fixed to badges parser which failed to limit shown badges to three with
invalid input.
- Fixed creating bookmark folders in bookmarks manager.
TeamSpeak3-Client-linux_amd64-3.1.9.run
SHA-1: a22f7bb46ff358ca819b7b91af66fb31697130fc
TeamSpeak3-Client-linux_x86-3.1.9.run
SHA-1: dccd8c9ca23a629862e734cfb7a3fe1881ada5a5
TeamSpeak3-Client-macosx-3.1.9.dmg
SHA-1: 9dca2c7d19e505ff73ffcd8ed6f2c72206bc03a3
TeamSpeak3-Client-win32-3.1.9.exe
SHA-1: 7d1a6b7bc01d2d0d2bd6ced486fca798944859a0
TeamSpeak3-Client-win64-3.1.9.exe
SHA-1: 594e1a1e42924b83e32e4086eab075633d612a7c
- Windows: Notify if microphone access is denied due to privacy settings
- Linux: Fix scrollwheel triggering mouse4/5.
TeamSpeak3-Client-linux_amd64-3.1.10.run
SHA-1: 4ed439e1d7ceb27d0f3483a811e45e6aa717d7fa
TeamSpeak3-Client-linux_x86-3.1.10.run
SHA-1: ea936dc3d43a29aa9fe7535ca0740e8407f18b89
TeamSpeak3-Client-macosx-3.1.10.dmg
SHA-1: 83647907f34b7b8dab76228b13f40271cbf1532f
TeamSpeak3-Client-win32-3.1.10.exe
SHA-1: f685a00ba7646b0f8ab20fc3bfbcbd75668e3c06
TeamSpeak3-Client-win64-3.1.10.exe
SHA-1: eea2e8248a94f343e73a3d65a0ed8b9a9faed464
+ Introducing our new TeamSpeak Logo.
teamspeak3-server_linux_amd64-3.0.13.8.tar.bz2
SHA-1: ac5038e946e31835db05a5ac107233a9989558fd
teamspeak3-server_linux_x86-3.0.13.8.tar.bz2
SHA-1: b93e7bce5355b5983e2f2d79d5a110e075f41512
teamspeak3-server_mac-3.0.13.8.zip
SHA-1: f86f5e37105518238ab502e54303897dc6e4cc6e
teamspeak3-server_win32-3.0.13.8.zip
SHA-1: 1ac8e200781a72190af6a0b1a805ea9f4b449395
teamspeak3-server_win64-3.0.13.8.zip
SHA-1: 33be5eca93669e3dcc88f92e10e2f4554c5b1070
Main features of Teamspeak 2:
- Compatible with legacy pcs such as Windows 98/ME and 2000
- Only support English and German languages
- Low quality voice, not the best but have the job done
- Enough slots to fill a lot of people in a server
- Cannot share files. It's targeted mainly for voice communication
+ Compatible only with 32-bit systems
+ 64-bit systems might need to install 32-bit libraries and dependencies
+ Linux users might require extra configuration to make the sound work. (Maybe installing Wine is a better alternative)
+ TS2 is NOT compatible with mobile devices or MAC systems officially.
> Compatible with Windows 98/ME requiring a Pentium 166 mhz processor and 64mb RAM.
> Compatible with Windows NT, 2000, XP requiring a Pentium II processor and 128mb RAM.
> Latest version for Windows client is: 2.0.33.7
In the address field type the DNS below:
or search in Web Server list for:
Retro TS2 PC Gaming
Windows
ts2_client_rc2_2032.exe
SHA-1: 666c23e4bf275d109475f03821790b9268f94ae0
Windows (Client update)
TeamSpeak.exe
SHA-1: 5b21f93b5574b067ac24515e1d43f7dde3297945
Linux
ts2_client_rc2_2032.tar.bz2
SHA-1: d54c9c19a2e70cee11f9a04a3523c71da802ee8d
Mac
teamspeex-1.0beta-r408.dmg
SHA-1: aa55db7ee2424e37cace28efa6dbe6a3e969ebd4
Windows
ts2_server_rc2_202319.exe
SHA-1: 010040a2f52ee91964df5bfb241a46ecc00afd21
Windows (Binary update)
server_windows.exe
SHA-1: 4e7e85a87b997f5091657402a5564b8e222a2819
Linux
ts2_server_rc2_202319.tar.bz2
SHA-1: 645dc564a7dda61212c8c6e7f2d5e6a3094f9c74
Linux (Binary update)
server_linux
SHA-1: fa589b3502f0f205395856b19374bb111f940f57
Possible Issues & Solutions:
If you have latest Teamspeak 3 version, only one Teamspeak can be installed and opened at the time. The workaround for this is installing one version choosing "Recommended: Save in user own files" and in a specific folder location and for the other Teamspeak 3 installation "Save inside the installation folder" and in a different specific folder location.
Any older Teamspeak 3 version, It'll constantly ask to update, we recommend having a Firewall and block the 'update.exe' file, so you don't update it accidentally. The file is located in the main Teamspeak 3 folder. (Keep in mind the latest version is only compatible with Windows 7 and beyond and thus It's not compatible with this server)
Yes! And It's very straight forward, since TS6 installs in a completely different folder in comparison to TS3. So there are no issues here, even the register path is completely different.
