New Windows 98 AM3 Build
First post, by Decivox
Ive been a long time lurker and gained a lot of knowledge in the process, so wanted to introduce myself and my build that I completed thanks to what I've learned here, elsewhere, and through some trial and error.
Intro:
Originally I wanted to get a 98 era pre-build from a manufacturer as I like the aesthetic and the period stickers they would throw on them (I love those e-Machines "NEVER OBSOLETE" stickers for example). After finally finding something locally in good shape, a Sony PCV-RX450, I ran in to two issues I hadn't thought about much - heat and noise. Without adding a GPU to it, it was already hot. Airflow is basically non-existent with a limited number of tiny fans, and the fans/PSU fan were loud, which brought me in to another issue, replacement parts. I managed to source a new PSU, but the airflow/heat/noise issues caused me to abandon the plan.
I ended up deciding I would do a build with (mostly) new parts for ease of purchase, efficiency, and thermals.
The Build:
I ended up finding a non-functioning computer in a beige case in great shape, with a decent amount of fan mounting areas, 2 IDE CD drives and a floppy drive. I gutted it, and then after researching, I ordered the parts for my build:
Motherboard - Onda A97S (New)
This was probably the longest part of the search. Finding a new motherboard with IDE, good expand ability, two PS/2 ports, and Windows 98 proved to be quite a challenge. After a lot of time watching marketplace, scouring eBay, and getting to page 150 of AliExpress I found the Onda A97S. It has everything except for a floppy port - I couldn't believe I would be able to use a brand new motherboard!
P.S - For anyone using this board, the Windows 98 chipset drivers are contained within VGA_XP32_070824.zip in the SBDrv folder. I know the archive says XP, but when you run the installer, it says "Windows 98 Driver" right on the splash screen. You can also add it with the .inf file through device manager.
CPU - AMD Athlon II 170u (Used)
I ended up going with the single-core AMD Athlon II 170u as it just sips power at a TDP of 20 watts. Apparently its just a Sempron with a core disabled and you can re-enable it somehow, but seeing as Windows 98 cant make use of it, I never tried.
GPU - Nvidia Quadro FX 1300 (Used)
I was originally looking for an ATI PCI-E card as I heard better things about the drivers, but for some reason they seem to command some decent money. On the other hand, it seems these Quadros were at least somewhat plentiful in workstation pre-builds and are often available at good prices as they are pulled from scrap machines to be resold. The first one I ordered didnt work, but the seller sent me another which did work. I ordered a replacement fan for it as the original was LOUD. They are quite plentiful on Aliexpress and eBay for under $10 under various renditions of "VGA PC Computer Video Card Cooler Cooling Fan Heatsinks For NVIDIA ATI Geforce". After pulling the stock fan off, it was apparent it was overdue for some fresh thermal grease anyways.
Soundcard - Audigy 2 ZS (Used)
This one took a little time to source as well, as a lot of the ones you see locally or online were the OEM versions which are cut down in one way or another, or cheap out (ie no gold) on the ports. I also seen reports of driver issues with the OEM ones so I wanted to stay away. Downloading the step by step driver install PhilsComputerLab made installation a breeze.
RAM - 2x 1GB DDR3 RAM (Used)
With one stick in, I can run the Windows 98 installer, run PATCHMEM, and then install the other stick later. Obviously this much RAM isnt required, but I couldnt find any 512 MB sticks of DDR3, 1 GB per stick was the smallest I could find.
NIC - Linksys LNE100TX (New)
Yes, thats right, I found this new, sealed in box. New old stock for sure. I havent set it up yet, but Id like to create a proxy locally that will let you browse webpages via the wayback machine, so I can check msn.com as I did back in 1999.
HDD - Patriot P210 128 GB (New)
New, cheap, and under the size limit for Windows 98 so I can avoid another patch.
The other remaining parts are a MSI MAG A550BN PSU, and an ARCTIC Freezer 7 X CO cooler as it fit in my case.
Reply 1 of 50, by old school gamer man
hmm why the Onda A97S and not the AM2NF3-VSTA? I would think it would have far better compatibility and its far less hard to find. Granted its am2+
Reply 2 of 50, by Decivox
old school gamer man wrote on 2025-07-28, 15:15:
This board and a few of the other ASRock options that are discussed often were on my list, but I was unable to find any available at a good price at the time. Even now a quick search on eBay for the AM2NF3-VSTA shows 0 results. Additionally, counter-tarrifs applied to electronics coming from the USA eliminated US based sellers, which did reduce my options a bit.
The Onda was readily available at the time for a good price, and had the ports I was looking for (minus floppy). I also liked that it was brand new.
Reply 3 of 50, by old school gamer man
Decivox wrote on 2025-07-28, 15:28:
ebay is not the only place to buy parts, but one or 2 come up on ebay about every month they just tend to sell fast. One sold from Germany just last month and not one long before that for 50$ form the uk. However if tarrifs are a problem for you I would be more worried about your income than a price of a motherboard. The most I seen a AM2NF3-VSTA go for is around 300 but most of them go for around 50 to 100. even with tarrifs and even if the tarrifs are say 500% that's will pocket change at best.
that being said I do find the Onda interesting. I like how it has holes for a VRM heatsink, the VRMs would likely run rather hot with 6 core PII so having the option to add one is nice.
Reply 4 of 50, by AlexZ
There are also other options such as Gigabyte GA-K8NS, Asrock K8NF3-VSTA or ASUS K8N-E with NVidia nForce3 250. Socket 754 CPUs are more than enough for Windows 98.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 ML-37@2.2Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 5 of 50, by old school gamer man
AlexZ wrote on 2025-07-28, 15:42:
anther one most seem to forget about is the Biostar K8M800 and that one is supper common. I had one for a wile, cheap board but its not bad for the price. you would likely have to recap it and it does not support PII and I bet that's why it gets looked over so much.
Reply 6 of 50, by Decivox
old school gamer man wrote on 2025-07-28, 15:41:
It has nothing to do with my income, why pay the government a 25% counter tariff and 13% sales tax, and then likely a some kind of courier import fee if not sent by USPS and sent by UPS, Fedex, etc? Now the $50 motherboard has doubled in price. The government already gets enough of my money, but thats not what this discussion is about 🤣
Returning to motherboard itself, like you said, the Onda is interesting. I found no chatter about it at all (besides chat about potential chipset compatibility on MSFN), so thought I would roll the dice and report back my findings as countless others have done here as well... its fun being a pioneer of sorts and spreading knowledge about feasible options to expand the hobby and make it more accessible. These 20+ year old parts aren't exactly becoming easier to source.
Reply 7 of 50, by old school gamer man
Decivox wrote on 2025-07-28, 15:58:
clearly it is about our income if your worried about at the most 150$... that's less than a tank of gas in some cars/places these days. Heck its less and eating out for dinner.
I never even knew Onda was a thing until now. how stable is it on 9x? And dose it give the option to disabled cores in the bios?
Reply 8 of 50, by Decivox
I actually have a ASUS K8N-E set aside for a Socket 754 system... I will get around to it at some point 🤣
Reply 9 of 50, by marxveix
Please share your VGA_XP32_070824.zip, thank you!
This VGA_XP32_070824.zip has WinXP drivers, not Win9x.
https://www.driverguide.com/driver/detail.php … riverid=1867709
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 10 of 50, by Decivox
old school gamer man wrote on 2025-07-28, 16:07:
clearly it is about our income if your worried about at the most 150$... that's less than a tank of gas in some cars/places thes […]
You got me, Im broke.. currently typing this out from Wendys Wi-Fi in the parking lot while running my Onda from the cigarette lighter looking at my negative Robinhood account.
Stability wise, so far its been solid. Disabled virtualization CPU tech in the BIOS, along with ACPI stuff, SATA to Native IDE... Running Nvidia 56.64 and it seems to be OK.
As for the CPU cores, the Athlon II 170u is a single core processor. In the BIOS I dont see any options to enable the second core, however I dont even know if its 100% possible. I just remember reading that it could be done on some motherboards as apparently the 170u is just a dual-core Sempron with one core disabled. But again, I cant confirm this.
Reply 11 of 50, by Decivox
marxveix wrote on 2025-07-28, 16:24:
I cant remember exactly where I got it, but the download from here returns the same file hash as the one I used.
https://drivers.softpedia.com/get/GRAPHICS-BO … ver-8-392.shtml
As I stated, the driver is in the SBDrv folder. If you run setup.exe in there, it will actually explicitly say its the Windows 98 driver once the installer opens. However, I just point the Unknown Device in Device Manager to the SBDrv\SMBUS folder and install directly from the .inf file contained there.
Reply 12 of 50, by Archer57
Curious build. Such a new platform would not be my first choice for 98 for sure. Mostly because of older game compatibility with pci-e graphics (though with that card it should be fine).
It is possible to make older hardware, s370/s478/s462 etc, reasonably quiet using modern fans and cases, but i do understand wanting old case because of looks...
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 13 of 50, by Decivox
Archer57 wrote on 2025-07-28, 16:37:
On the topic of graphics, I should note the Quadro FX 1300 does support table fog, but unfortunately doesn't support palleted textures, which I thought it might considering the cards lineage.
Reply 14 of 50, by old school gamer man
I mean, if you are using Robinhood for investing you likely are not doing all to well... yest saying.
if you are using a one core cpu you would likely not see the option to disable cores.
Decivox wrote on 2025-07-28, 16:48:
technically only 3dfx cards have those, any other card emulates it. Unless if you are playing ff7/8 or shadows of the empire you likely would never need it. However there are wrappers granted I don't know if they work in 9x
Reply 15 of 50, by Decivox
old school gamer man wrote on 2025-07-28, 16:50:
That was the joke..... Robinhood, Wendys....
Reply 16 of 50, by old school gamer man
Decivox wrote on 2025-07-28, 16:51:
I know 🤣 and Robinhood is a horrible place to invest with. They are borderline scammers who are well known to manipulate the markets and that's not getting into their fees 🤣. that made your joke even funnier.
Reply 17 of 50, by AlexZ
If you are a hedge fund and seek alpha, one of the ways is to find the worst investors on the planet who significantly underperform S&P 500 and short their trades. It isn't necessary for these investors to lose money, all is needed is significant underperformance. A prerequisite would be a "free" broker sharing trade information with such a hedge fund. "free" brokers need to make money somehow after all.
Reply 18 of 50, by old school gamer man
AlexZ wrote on 2025-07-28, 17:18:
TBH anyone investing in the S&P 500 fund like voo is losing regardless but this is getting off topic 🤣.
Reply 19 of 50, by The Serpent Rider
old school gamer man wrote on 2025-07-28, 15:44:
AM2 version has only 2 PCI slots and realistically only one usable, if decent AGP cooling is required.
