First post, by songoffall
- Member
Here I'll try to chronicle my attempt repair of an MSI GeForce 6800 card. Attempt - because I'm not convinced I will get it working in the end.
I have some experience with board-level repairs - but I have done it motherboards and graphics cards with less component density.
The card came in a very rough shape. All solder pads were black with corrosion. Everything was caked in dust and gunk. The card also has signs of physical wear, although not on the PCB itself but the cooler cover. The fan has been replaced and not with an original part - basically a fan of the same width has been glued to the cooler.
I did not feel like putting this card into any retro PC I have as it was, so I went over all the corrosion with concentrated acetic acid, then washed the card and then gave it an IPA bath. I wish I had one of those ultrasound baths to completely clean the card.
Sadly I forgot to take before photos of the card, but here are the after photos:
As the card had conductive thermal paste I cannot verify if some of it has slipped under the solder balls of the GPU.
Next step was to test the power contacts to make sure none of the power rails were shorted and that the card was safe to power on.
Here's the pinout of power on a PCIE card:
None of the power contacts was shorted to ground.
I plugged the card into the following tested working system:
Intel DG35EC Eva Cove
Intel Pentium Dual-Core E2160
2Gb DDR2 DRAM
To verify the system (it has Intel GMA X3500 onboard graphics) I first plugged in a known working GeForce 8600GT card. It worked as expected.
I plugged in the GeForce6800. Turned on the system. The card's fan made a couple of spins and stopped. No video output. Card not detected on system. Onboard video output working. Card not showing in Windows XP either.
This is where we are now with the repair, and as I couldn't find any diagrams online I'm gonna have to think of steps to diagnose and troubleshoot the issue and hopefully get the card working.
Pentium 2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 2.0GHz/GeForce4 Ti4200/Sound Blaster Live!
Core2Duo Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
