First post, by tomeldee
- Newbie
Hello!
I'm new here - although I have been reading lots of topics and posts here before, and got many help. So thanks for that!
For this issue I didn't seem to find anything, so I'm placing my faith in you guys 😀
I have just built a Tualatin Celeron 1200 machine with a Geforce 3 Ti200 videocard, and it doesn't seem to work properly.
This is the config:
PCPartner AP133TAS3-T222C
Intel Celeron 1200 (Tualatin) - will be replaced with a P3 1400-S
1x 256MB 133MHz SDRAM - will be upgraded to have more
It runs a Win98SE, with the VIA 4-in-1 driver and the some version of the nvidia driver installed. (I know it matters which version, I'll check which one I have if necessary).
As I didn't have these hardwares when I was a kid, I really don't have a memory how fast should it be.
I had a 466 Celeron and then a 2400+ Sempron many years later, so I kinda missed out on the P3-P4 wagon.
I tried 3 games to check it's performance:
Delta Force 2 ~10-15 fps
Vietcong ~ 15-30 fps
Mafia ~ 20-30 fps
Tonight I'll check with 3dMark2001
I'm good at modern hardware repair, so I'm not a total noob.
So if someone could just point me in a direction I should go in the troubleshooting, I would be really grateful!
Thank you so much!
Tom
Regards, Tom
A proud owner of:
Zida 495SLC Rev. T.1 (VLB) | Intel i486DX2 66MHz | 8MB FPM RAM | Trident TGUI9400CXi VLB 2MB
PCPartner AP133TAS3-T222C | Intel Pentium-S 1400MHz | 512MB 133MHz SDRAM | Inno3D nVidia GeForce 3 Ti200 64MB
..and more
