First post, by jude1977
hi all
I've downloaded flight simulator version 3 dos copy and I'm trying to get it to work on
my windows 98 pc but every time I try and run it it says program to big to fit in memory
I've tried increasing my virtual memory but that hasn't made any difference although
I must admit I'm not Shure whether I did it wright does any one know how to fix this problem or a way around it
I've taken a image of the version of flight simulator I'm trying to use to show you all.
Reply 1 of 47, by Kalle
You need to increase your conventional memory. If you type in mem, you can see how much is available. The manual should tell you how much you need.
Reply 2 of 47, by DaveDDS
Yeah, I just found and played with my original FS3 floppy - Ran it fine under DosBox (which has lots of conventional memory),
and a DOS5 machine which doesn't keep a lot of extras ... Don't know how much conventional memory W98 takes, try booting W98
directly to DOS (don't even start WinBlows) and see if it runs.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 3 of 47, by DaveDDS
Just booted up Win98 in PCEM
- Under Win98 -> DOS prompt = 605k free
- Restart in MS-DOS mode = 606k free
(Looks like W98 loads itself mostly into extended)
Booting MS-DOS5 in PCEM:
- Largest executable program size: 627040 (612k assuming k=1024)
(Not a whole lot more than Win98 - I don't know what FS needs)
Reply 5 of 47, by jude1977
hi all I've given memmaker a try and tried extending conventional memory as well as expanded memory but it doesn't seem to make any difference this is on my 486 pc but I'm not Shure
how to run memmaker on my windows 98 pc so I wasn't able to try on my windows 98 pc.
I tried typing memmaker in dos mode on my windows 98 pc but nothing happened.
Reply 6 of 47, by OzzFan
Memmaker doesn't exist in Windows 98 because managing conventional memory became a thing of the past when running 32-bit Windows applications. Are you running FS3 from within Windows or after you exit to DOS mode? Can you provide the output of mem.exe here for us to see?
Hobbyist Developer : https://www.shelteringoak.com/du/
Reply 7 of 47, by DaveDDS
Ok, I just fired up flight sim V3 under Win98 (native - not booted in DOS mode) running in PCEM
It started and ran fine.
"mem" shows "Largest executable program size 605k"
Then I wrote "usemem" - a program to allocate nK of memory and then run a program:
A:\FLTSYM> usemem 300 mem
shows "Largest executable program size 297k"
A:\FLTSYM> usemem 300 FS3
Loaded and ran FS3 jsut fine as well!
So, It looks like the 256k requirement mentioned earlier in this thread is accurate!
What does MEM show on your system?
If >256k, the problem may not be amount of memory - what EXACTLY is the error message you get?
Reply 8 of 47, by Ringding
The problem is much more likely to be too much free memory instead of too little, because there was no HMA or UMBs or MemMaker and such at the time, and also the majority of systems probably still had at most 512 KB, so it was very uncommon for people to have so much free memory in the first place.
Reply 9 of 47, by Ringding
You could also try LOADFIX
Reply 10 of 47, by DaveDDS
Ringding wrote on 2025-10-20, 17:06:
Possibly, but I ran FS3 under a fresh/bare install of W98 where MEM showed 605k free (I expect quite close to the maximum you can have) with no probs.
This is from a original Ms FS3 diskette that I bought new "back in the day".
I'm thinking something else installed on the system may be causing a conflict of some sort.
Have you tried running it in "Restart in MS-DOS" mode?
Reply 11 of 47, by Jo22
By late 1980s, HMA was in use by Windows/286 I think..
UMBs were in use, too, via dedicated RAM cards.
Conventional Memory was up to 704 KB, or 736 KB in CGA systems.
More information in my thread over here:
Re: 80x86/Vxx PC emulators with x87, EMS, UMBs and no artificial 640KiB limit ?
Edit: That being said, there indeed had been lower-end PCs, too.
The Schneider PC1512 had 512 KB by default, with a provision for full 640 KB expansion on motherboard (free RAM sockets).
Or the Amstrad PPC 512, that portable XT with the oversized GameBoy screen. 😉
Edit: Speaking of alternatives, FS4 had better physics but looks quite similar to FS3.
Also, FS3 was being said to feel like someone's "flying on rails"..
Or how about FS2 for the Amiga? It was like PC version of FS3 in terms of features (MS FS3 for PC was a bit behind).
It also had best graphics (more than 16c), perhaps.
There's a great review: https://shot97retro.blogspot.com/2020/06/flig … epth-amiga.html
Reply 12 of 47, by megatron-uk
Does FS3 use XMS? Is it perhaps one of these games which freaks out if XMS is over 8/16/32MB and causes some overflow error in its memory calculations?
If it does use XMS, it's possible that it's this which is causing the memory issues and not actually the available free base memory (which as illustrated above, seems to work fine all the way down to just a few hundred kbytes).
https://www.target-earth.net
Reply 13 of 47, by jude1977
hi interesting what is xms
Reply 14 of 47, by megatron-uk
https://en.wikipedia.org/wiki/Extended_memory
It's a mechanism for accessing memory above 1024kbytes in DOS. It, and Expanded Memory (EMS) were the two earliest ways that DOS applications could use more than 640kbytes, until protected mode applications started to appear with the introduction of the 386 CPU.
Some early applications can misbehave when they attempt to detect how much free XMS (or EMS) is available and they detect way more than they assumed would be available.
Reply 15 of 47, by DaveDDS
According to the tech pecs posted earlier in this thread, it has a minimum RAM requirement of 256k
I recall using it under DOS back in the day and I never had XMS or EMS setup on that machine.
Seems unlikely that it uses either - just conventional RAM. If some wants, I can configure PCEM to have
only conventional RAM and give it a try.
Reply 16 of 47, by DaveDDS
FWIW, I just ran MS-FlightSim-V3 on a system running Dos5 with only 640k conventiolan memory without any probs...
No EMS/XMS required!
Reply 17 of 47, by jude1977
very interesting maybe its because I'm trying to run it on a windows 98 pc that I'm having trouble running it
Reply 18 of 47, by jude1977
hi i noticed you said FWIW what does that mean and when you said you ran it through DOS 5 was that a machine that's got windows on it and if so what
version of windows and was it a downloaded copy of flight simulator 3 or a retail copy
Reply 19 of 47, by DaveDDS
jude1977 wrote on 2025-10-24, 07:47:
if you look back through this thread, you will see that at one point I ran it under Wn98 without problems.
I think either something you have loaded in Win98 is causing interference with it, or you copy of FS3 is bad.
Have you tried "Restart in MS-DOS" - this will reboot Win98 and NOT load the GUI and related background activity.
I also tried this and it worked fine.
If it works, you will not that your copy is good. If not, then I would trust the integrity of you copy less (but you would still have to insure that nothing is getting loaded in W98-DOS config.
