Power LED always on
First post, by Amigaz
I recently built a socket 7 motherboard out of a DFI 586ITOX motherboard.
The problem I am facing is that the power LED is on even though the computer is shut down. I am almost starting to suspect that the is something hardware related and I am out of ideas.
Does anyone have a clue what can be at fault here?
Reply 1 of 2, by Joseph_Joestar
Amigaz wrote on 2025-10-25, 15:49:
The QDI Titanium IB+ has a similar issue.
On that board, it can be worked around as per the instructions here. Not sure if that's applicable to your board as well, but it might be worth a shot.
My retro stuff
Reply 2 of 2, by StriderTR
Looking at the manual for that DFI 586ITOX board, it looks like it may be a multi-use LED. I suggest looking into what joseph suggested. That's where I would start.
The manual can be found here: https://theretroweb.com/motherboards/s/dfi-586itox#docs
It seems there are a couple options to plug in that LED on the board? It seems to also double as a temp warning LED.
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
