First post, by bitzu101
Hello again,
I decided to show off my second (out of the 4) retro pc s.
Here are the specs:
Mobo gigabyte socket 462 with via chipset
AMD athlon xp 1700+
512mb ddr1 ram
40 gb hdd
GeForce 4 ti 4200 128 mb
2x dvd rw
Floppy
Nokia case.
It runs windows me. And contrary to what all think about windows me 🙃, I actually like the os.
Reply 1 of 19, by gerry
bitzu101 wrote on 2025-11-03, 09:06:
Hello again, […]
Hello again,
Here are the specs:
AMD athlon xp 1700+
512mb ddr1 ram
40 gb hdd
2x dvd rw
Floppy
Nokia case.
looks like smart case to me and the specs are great for windows me, my guess is that the machine will happily chew through almost any late 90's and early 2000's game - and a few later ones if you are happy to lower res and settings a bit.
what do you like about Me? i've tried it, its fine- but i always end up back with 98se or forward to XP, there never seems to be sweet spot / niche for it when it comes to games/application compatibility not covered by the other two. Still, thats no reason not to use it, its still fine
Reply 2 of 19, by bitzu101
gerry wrote on 2025-11-03, 17:13:
Hello again, […]
Hello again,
Here are the specs:
AMD athlon xp 1700+
512mb ddr1 ram
40 gb hdd
2x dvd rw
Floppy
Nokia case.
I like ME , it s a lot quicker than 98se and pretty much same functionality. I never play dos games in actual dos. I always play from windows , so i don t ever need specific dos drivers , all that complicated stuff.
Now , I also have a win98se machine , and 2 more xp machines , so , ME , it s the perfect choice for this pc.
I think that if Microsoft had put in a little bit more effort in ME , it would have been the clear choice before win xp.
Funny enough , never had an error or any problems so far with this machine. I think the only component missing is a PSU that has a fan at the back , rather than the bottom. I will find one eventually that I like.
Also , I forgot to mention , obviously , I have a ess solo 1 as a sound card. Sometimes i alternate it with a yamaha 724 , but for whatever reason , I always end up with the ess.
Reply 3 of 19, by chinny22
ME's lack of actual dos was always my main complaint so if your not needing that then indeed it makes alot of sense.
Moreso now if you have multiple retro rigs, you need something to make it stand out form the others.
Don't think I've seen the case before, Kinda cool how the bottom looks like an old Nokia phone
Reply 4 of 19, by pete8475
Hello again, […]
Hello again,
Here are the specs:
AMD athlon xp 1700+
512mb ddr1 ram
40 gb hdd
2x dvd rw
Floppy
Nokia case.
Nice PC, love the case!
I also use ME on my main retro machine which is a socket 775 P4.
Rebuilt my P4 yet again
Reply 5 of 19, by 65C02
Which version of Ti 4200 is that? I've never seen one with external power like that!
Reply 6 of 19, by bitzu101
65C02 wrote on 2025-11-04, 06:55:
Sorry , that is an older photo , that card is a 7600gt.
I only used that card because the colour scheme matches. I have a few ti 4200 , but i am waiting for a blue one in the post this week that should make it all blue , except the sound card.
Reply 7 of 19, by bitzu101
pete8475 wrote on 2025-11-03, 22:54:
Nice PC, love the case! […]
Hello again, […]
Hello again,
Here are the specs:
AMD athlon xp 1700+
512mb ddr1 ram
40 gb hdd
2x dvd rw
Floppy
Nokia case.
I have a 775 machine as well , that is a win xp machine , will post it on here eventually... That is my very late win xp machine with pci e , etc...
The case is brilliant , looks like a nokia phone , probably the 5210 , like the way the LED s light up...
Reply 8 of 19, by ciornyi
Wow thats a good build , but according motherboard's name its AMD 761 chip. Im thinking about same setup for dx 8 games . Im havent decided but im thinking about intel 2.8Ghz and 845e combo or amd 2500+ and sis 746.
DOS: 166mmx/16mb/Y719/S3virge
DOS/95: PII333/128mb/AWE64/TNT2M64
Win98: P3 900/256mb/SB live/3dfx V3
Win Me: Athlon 1333/256mb/Audigy2/Geforce 2 GTS
Win XP: E8500/4096mb/SB X-fi/Quadro fx 4500
Reply 9 of 19, by TheIpex
Great looking build, I really like that motherboard. I also agree Windows ME is a good fit for such a system.
Pentium MMX 233 & 3DFX Voodoo
Reply 10 of 19, by chinny22
I missed the fact everything was blue. Someone else did the same here few years ago and I think it makes for an interesting and different system.
Blue soundcards do exist, unfortunately they aren't anything special (at least Win9x compatible ones)
Reply 11 of 19, by bZbZbZ
Nice system!
I also have a soft spot for Windows ME. I remember back in the day, I didn't really find it any less stable than Windows 98 (they were both roughly equally dodgy on the hardware I was using!). What I do like about Windows ME is that the default UI color scheme has a slightly lighter/blue gray than the gray used by Win95/98. And the title bar gradient had different shades too, matching Windows 2000. When I was a kid I had written down the color codes so that I could make Win98 match Windows 2000 but that was quite tedious...
The lack of pure DOS also made WinME boot faster. In the use case where you're not interested in pure DOS (you have another DOS retro machine, or are happy enough with DOSBox), WinME makes a lot of sense!
Reply 12 of 19, by bitzu101
TheIpex wrote on 2025-11-04, 21:50:
The mobo I found on ebay , in perfect condition and with original box as well , all cd s and the ide cables and floppy cables.
Reply 13 of 19, by bitzu101
chinny22 wrote on 2025-11-04, 23:38:
Yeah , i did look for a blue sound card , but I only found CMI chipsets and the CMI cards are horrible.
Reply 14 of 19, by bitzu101
bZbZbZ wrote on 2025-11-05, 20:53:
Nice system!
I have 4 retro pc's , including a win98 pc. I never use pure dos as I find it pointless. There is nothing on there that I need , also , I have no games that i need to start in pure dos. All games work directly in windows 9x. Even for my win 98 machine , I never reboot into dos , etc.
Actually , I remember in the olden days , they used to teach us in school DOS , and then win95 came out and then DOS was completly pointless. I remember being very happy i don t have to use the os with command line interface.
Reply 15 of 19, by Mondodimotori
Nice system indeed,
I also have a 462 Me system, (soon to be two). It was my first ever x86 machine, and last year I upgraded it a bit: Currently it has a 1.4ghz athlon classic and a PCI card. Unfortunately it was a cheapo mobo, so only IGP and no AGP slot. (the reason for my second Me system on its way).
I also have a soft spot for Me since it was my first Windows OS (still got the license sticker on that system). But for another 370 system I have, I'll probably go 98se for DOS support. Maybe in the future I'll make a thread about it for hep, since DOS is totally alien to me.
Reply 16 of 19, by bitzu101
Mondodimotori wrote on 2025-11-06, 12:44:
Nice system indeed,
Dos it s only worth it if you know you have app that would only run from native dos. besides that would be only nostalgia , but if you never had to use dos back in the day , it s useless and a pain to use. I still remember some commands , but not a lot.
Win 98 and ME or 95 are more than enough to run 99% of dos apps straight from windows , without the need for pure dos.
If you do a ME machine , as you said , need a mobo with agp , if you find , or have money to spend , buy a voodoo 5 5500 , that is probably the most sought after gpu in any retro machine.
Reply 17 of 19, by Mondodimotori
bitzu101 wrote on 2025-11-06, 13:08:
Alredy found one but no, I'm not gonna jump on the 3dfx bandwagon. Too expensive, it almost feels like a cult.
I just put in it an FX5600 that supports good 9x drivers, and also have a ti4200 to spare (even if it's dying). If push comes to shove, I also have an MX440SE in the 370 system, and even a cheapo TNT2 M64 (that's just a bit wobbly)
But thee advantage of an FX5600 is DX9 and the ability to run Glide wrappers with it.
I'm just waiting for a cople of new CPus to arrive to finish that build and install Me.
Reply 18 of 19, by bitzu101
Mondodimotori wrote on 2025-11-06, 22:32:
Alredy found one but no, I'm not gonna jump on the 3dfx bandwagon. Too expensive, it almost feels like a cult. I just put in it […]
Use the 4200. Or the 440.
Reply 19 of 19, by Mondodimotori
bitzu101 wrote on Yesterday, 14:36:
Unfortunately that Ti4200 is on it's way for GPU heaven. When I got it had artifacts like crazy, couldn't even use windows correctly. I used the refund money to have it fix and, miracle, they did manage to somehow fix it. Some pixels will still artifacts during gaming and benchmarks, but it's usable. Of course, it's not usable on the long run in a stable system.
The MX440SE... yeah, that's not very fast. I got it to turn that system in a 98se/DOS system.
The FX5600 fits the bill perfectly for DX8 and lower gaming. Paired with a Barton 2600+ I get more than 9500 points in 3dMark 2001. I think anything faster for a 9x system would be pointless.
