First post, by Danilo_Dias
For some reason 2/3 of times I try to tub my PC off with windows 98 it doesn't proper turn off. It quits windows and shows a black screen with just the blinking dos white dot but the Pc itself doesn't turn off.
When I turn off and turn on the PC search for errors as if I didn't turn it of properly, any tips?
It's a p3
GeForce 4 MX
Windows 98se
Reply 1 of 1, by chinny22
Win98 struggles to shutdown at the best of times, just look at all the reasons MS list in their own KB article!
https://www.betaarchive.com/wiki/index.php?ti … _Archive/238096
MS released 3 patches, not that they work for me very often and the last 2 only make a difference if you have a network card installed.
KB239887 Shutdown Supplement
Q260067 Mapped Drives Shutdown Update (if PC is on the netw0rk)
Q242934 Windows hangs sending system broadcast message during shutdown
As you list your using a Nvidia card, driver version 81.98 is a known cause.
