First post, by fsinan
Found a NewTech/SMT SMT486 Terminator with Ali M1487/1489 chipset. I think this one is strong with the force, giving far better results from UMC and SIS chipset. Tests done with 5x86 at 120Mhz, 40x3. Better memory results with better benchmark results. Better memory timings achieved with same viking FPM memory modules, rock stable. I have other tests in vogons with other chipsets, sorry couldnt find old photos for comparison. You can find here at my older posts.
System:1
Cyrix 5x86-120GP & X5-160ADZ
Lucky Star LS-486E
System:2
Intel DX4-WB & AMDDX4-120
PcChips M912 V1.7
System:3
AMD K6-2-475 & Cyrix 6x86MX PR-233
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 1 of 2, by bertrammatrix
Interesting.
Indeed, I have also found the FinALI chipset to be faster then SiS as well, however it always ended up being slower then any UMC based m919 boards I have. Usually what I run in to is that L2 is only marginally faster than main memory, especially with faster FSBs.
I'm guessing you have the cyrix enhancements enabled to get that CPU score.
Can you provide cachecheck results?
Have you tried running at 2x60 mhz instead? This can net you an extra 1-2 ish fps in quake along with obviously higher memory speeds though alchemy with the cache may be needed.
Reply 2 of 2, by fsinan
bertrammatrix wrote on 2025-12-08, 16:37:
Interesting. […]
Interesting.
Yes cyrix enhancements used.
Will check for 2x60Mhz.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
