First post, by NiGHTSaturn
Hello everyone,
I had my first PC at 8 years old. I honestly never looked what was connected to its motherboard and also could barely speak any English then.
After years of trying to find something as close as the sound card that was installed in the PC my family got rid of quite quickly after its PSU died, the few things I can mention is that the sound was quite close to OPL 2 or 3.
I recorded something from an old game I played (one of those fan Klik n Play games) and still have that recording. I managed to run the game again with Win98 Emulation with VirtualMIDISynth with the OPL-3 FM 128M soundfont but it wasn't as close. If anyone can help out to figure it out, I'm leaving a YouTube clip with the old recordings I did.
The first clip came from my old sound card. For some reason, its frequency isn't as clear. Like if the recording went from 44.1 to 22.05. But at least, there's an example!
The second clip is not from my sound card but a wav file from another game where the programmer prerecorded it. I would also love to find out which sound card it was and if there's a soundfont for it!
I also found the original Midi file that the programmer used! I tested over 100 soundfonts and couldn't reproduce the sound you will hear in the clip.
One more thing. The only thing I remember from my PC is that there was Trident hardware inside. I think it was the video card, and not a 4DWave DX card. After hearing its virtual synth samples, my old PC never sounded like that.
If I need to produce a comparison between my old soundcard capture and a quick recording of how it sounds with the OPL-3 FM 128M sf, I will do it too.
The video will have a chapter if you don't want to listen to the entire 1:32 of the first clip.
https://www.youtube.com/watch?v=1F7_5CeG2Q0
Thank you very much to everyone, I appreciate all the help!
Reply 1 of 25, by cyclone3d
Download DOSBOX and run a game with the OPL3 emulation.
A midi synth with an OPL waveset is not going to be very accurate at all as the technology is completely different.
Edit: after listening to th video, it definitely sounds like some sort of wavetable.
What year was this?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 25, by NiGHTSaturn
cyclone3d wrote on 2026-01-05, 18:58:
Download DOSBOX and run a game with the OPL3 emulation. […]
What year was this?
Like I said, the soundfonts i've tested are nowhere close to what I used back then. I believe this PC was built in 1998. Thanks.
Reply 3 of 25, by cyclone3d
I'm wondering if it was using the Microsoft GS Wavetable Synth that was available in Windows 95 and higher.
If built in 1998 it would have either come with Windows 95 or 98.
YMF7x4 Guide
Reply 4 of 25, by NeoG_
The first clip sounds like good old FM synthesis, but I don't know what exact variant. Could be OPL, CQM, ESFM etc going through the windows 95/98 midi mapper. The second clip is probably the built in Win98 GS Wavetable.
Reply 6 of 25, by NiGHTSaturn
NeoG_ wrote on 2026-01-06, 02:03:
It really is! Sounds a lot like OPL, but maybe not as harsh sometimes. I'll work on another clip with the game playing with the soundfont (OPL 3) so we can check the difference. Thanks for your input!
Reply 7 of 25, by NiGHTSaturn
cyclone3d wrote on 2026-01-06, 03:38:
What exact game was the audio played / generated from?
If we can figure that out, it is going to be much easier to figure out what type of card the music came from.
The first one is a fan game of NiGHTS Into Dreams, the midi files are embedded in a Klik n Play enclosure, so you need to play the game to play the audio files. As I said in my last reply, I will make another video trying to play the track again with an OPL3 soundfont so we can hear the difference more clearly. Thank you for your input!
Reply 8 of 25, by cyclone3d
NiGHTSaturn wrote on 2026-01-06, 08:59:
Soundfonts are not going to sound anything like the original.
If it was wavetable, even with the same soundfonts, it is going to sound different on different synths.
And an OPL soundfont is not going to sound anything like real OPL.
YMF7x4 Guide
Reply 9 of 25, by Jo22
There's an OPL3 emulator for Windows XP.
It should do for MIDI about as good as an SB16, but I haven't really tested it.
Windows, Doom, Apogee OPL3 Synthesizer.
https://github.com/nukeykt/WinOPL3Driver
Reply 10 of 25, by cyclone3d
Doing some more research and here is what the manual says as far as music support goes:
"Music for this picture
Selects a musical accompaniment. The entries are shown in a “play list” to
the left of the screen.
Play Plays through the entire play list.
Klik & Play User’s guide
35
Remove Deletes the selected piece of music in the play list.
Random Plays the list in a random order while the picture is being displayed.
Keep Previous Music
Continues to play any music left over from the previous frame. When this
finishes, a new piece of music will be selected from the play list.
Add Inserts a piece of music into the current play list. This music should be
available from a standard “.MID”, or “.MUS” (Windows version only) file.
You can choose your music using a selector:
Midi file enters your music from a midi file in “.mid” format."
So this means the game had to use either a .MID or .MUS file for the music.
With the sound of the music and what Klik & Play supported, you must have had a card that had included an FM MIDI driver for Windows.
Per ChatGPT:
On Windows 95/98/ME, Creative’s ISA SB16/AWE driver stacks typically install an MME MIDI output device called “Creative FM Synth” (or similar). That device renders standard Windows MIDI through the card’s FM synth block — i.e., the OPL3 path on cards that have real Yamaha OPL3 (or through Creative’s CQM “OPL-compatible” block on later cards).
You can see this in Creative’s own AWE64 Gold readme: their “Virtual MIDI Driver” can route MIDI to multiple devices, including “FM” (device code 10) on the card.
astonisher.com
ISA Sound Blaster families that came with that Win9x “FM synth” MIDI device
These are the big buckets that (when using Creative’s Win9x drivers) expose FM/OPL-style MIDI playback:
Sound Blaster 16 (ISA) — including the many CTxxxx SB16 variants
SB16 retained OPL-3 FM synthesis support; later SB16-era boards may use CQM instead of a true Yamaha OPL3, but the Win9x “Creative FM Synth” concept is the same.
Wikipedia
Sound Blaster ViBRA 16 (ISA) (SB16-derived OEM/value boards)
These are SB16-class designs; depending on exact model/revision they may have real OPL3 or integrated CQM, but they’re in the same Win9x driver ecosystem as SB16.
Wikipedia
Sound Blaster AWE32 / Sound Blaster 32 (ISA)
These have the SB16 “FM + digital” section and the EMU8000 wavetable synth section; DOSDays explicitly notes the AWE32 includes Yamaha OPL3 as part of that FM/digital section.
DOS Days
Sound Blaster AWE64 (ISA)
Same overall idea (SB16-class + EMU synth), and Creative’s Win95-era readme explicitly includes routing to FM as a MIDI destination on the card.
astonisher.com
+1
Quick “gotchas” (so you don’t get tricked by model names)
This is about Windows MIDI (MME) → FM synth. That’s different from DOS games that talk directly to OPL registers (AdLib/SB music). In Win9x, you’re choosing a MIDI output device like Creative FM Synth in MIDI Mapper / app settings.
SB16 PCI / AudioPCI-era “SB” cards are different: they generally don’t have real OPL hardware; FM is usually emulated and not what you’re asking for.
Wikipedia"
Other brands / audio chips that had FM MIDI drivers for Win9x:
"Were there any other brand's isa sound cards that had an FM MIDI driver?
Yes. Several non-Creative ISA sound cards for DOS/Windows 9x shipped with Windows MIDI drivers that exposed an “FM Synth” (OPL-based) MIDI output, similar in concept to Creative’s “Creative FM Synth”. The key requirement was having an OPL2/OPL3 (or compatible) FM block and a Win9x MME MIDI driver that routed MIDI to it.
Below are the main families that did.
Yamaha-based cards (the cleanest, most “correct” FM MIDI)
These used real Yamaha OPL3 cores (often integrated into the chipset) and almost always had FM MIDI devices in Windows 9x.
● Yamaha OPL / YMF7xx ISA cards
Typical chips:
YMF719
YMF718
YMF715
YMF701
Examples:
MediaVision Pro Audio Spectrum–compatible Yamaha cards
Generic “Yamaha OPL3-SA” ISA cards
Windows 9x MIDI devices commonly shown:
Yamaha FM Synth
OPL3 FM Synth
These are gold-standard FM: real OPL3, excellent timing, very DOS/Win9x friendly.
ESS Technology (very common OEM cards)
● ESS Technology AudioDrive ISA cards
Typical chips:
ES1688
ES1868
ES1869
Windows 9x drivers usually expose:
ESS FM Synth
FM Music
Notes:
FM is hardware OPL3-compatible (not software)
Sound quality is slightly different from Yamaha but very good
Extremely common in OEM systems (Packard Bell, Gateway, etc.)
Aztech (widely sold retail & OEM)
● Aztech Sound Galaxy ISA
Typical chips:
AZT2316
AZT2320
AZT1605
Windows 9x MIDI:
Aztech FM Synth
OPL Synth
Notes:
Usually true or near-true OPL3
Drivers are simple but functional
Popular in mid-1990s budget PCs
OPTi (often overlooked, but real FM)
● OPTi ISA sound cards
Typical chips:
OPTi 82C929
OPTi 82C931
OPTi 82C933
Windows MIDI:
OPTi FM Synth
FM Music
Notes:
FM block is OPL3-compatible
Good DOS compatibility
Less polished Windows mixers, but MIDI FM works
Crystal Semiconductor / Cirrus Logic
● Cirrus Logic Crystal ISA cards
Typical chips:
CS4232
CS4236
CS4237
Windows MIDI:
Crystal FM Synth
Important caveat:
FM is often emulated or hybrid
MIDI FM works in Windows, but not register-accurate OPL
Fine for General MIDI → FM playback, not ideal for purists"
There are also a ton of different cards that used an external Yamaha or Yamaha clone OPL2 or OPL3 chip.
To figure out exactly what FM chip it was (I have cards with all the different FM implementations as do many others here), we would either need the original music file or the Klik & Play game.
YMF7x4 Guide
Reply 11 of 25, by cyclone3d
Installed DOSBOX and used a midi player program playing through the OPL3 emulator and tried all of these and none sound anything like the song in the video:
https://www.khinsider.com/midi/saturn/nights-into-dreams
Here is a site with all of the original songs from the game and playable in the browser:
https://downloads.khinsider.com/game-soundtra … -full-selection
None really sound like the song in your youtube video.
There are a couple other pages on that same site with different compilations of the songs from the game.
YMF7x4 Guide
Reply 12 of 25, by Ozzuneoj
Do you still have the that fan game? You can just upload it here if that's the case, since it isn't a copyrighted thing. It will be much easier to figure out what sound card was used if we can hear the music on our own hardware.
If I can get a way to play the track myself I will volunteer my soundcard collection to help figure this out. I have a pretty decent selection of cards with wavetable onboard which likely aren't going to sound anything like the soundfonts available online. It sounds FM-like, but then some lower end wavetable synths can sound like that too.
Reply 13 of 25, by NiGHTSaturn
Ozzuneoj wrote on 2026-01-07, 04:26:
Hello! I do! Since it's a Klik n Play Game, after the install, you may need to add the "missing DLL file" that has to be put back again in the programs directory. I'm sorry it took a few days to reply, I don't get notifications when I get answers back from the forum. I'll get this ready to go today!
Also thank you everyone for so much important info, this community is great!
Reply 14 of 25, by NiGHTSaturn
Here is everything! New video with where to put the missing DLL file after install. I even found the original Nutcracker Midi file and I have a feeling when the wav file was recorded (For Gemstorm), they removed a few strings.
https://youtu.be/2Uvjc7a0V14
Reply 15 of 25, by NiGHTSaturn
NiGHTSaturn wrote on 2026-01-08, 13:46:
Another quick mention for the linked video: UTM makes the music slower. But at least, I can use VirtualMIDISynth to use the soundfont.
Reply 16 of 25, by leileilol
FWIW the midi of the first song is MELSMAD.MID. it's a Click & Create / Games Factory library file, and to me it sounds like OPL3 but put through timbres that aren't windows' OPL3 FM driver. It isn't SuperSAPI though, and doesn't sound like CQM either
long live PCem
Reply 17 of 25, by NiGHTSaturn
leileilol wrote on 2026-01-08, 14:09:
FWIW the midi of the first song is MELSMAD.MID. it's a Click & Create / Games Factory library file, and to me it sounds like OPL3 but put through timbres that aren't windows' OPL3 FM driver. It isn't SuperSAPI though... It's also possible the midi was modified because those aren't sounding like pianos
Wow that's good information too. Way better to test the cards than running that old game! Also, it does seem like there's more Celesta/Vibraphone/Bells effects, and harmonics are different too.
Thank you for the name of the midi file. I found it, but I don't know if files from an old Factory Library are ok to share here.
Reply 18 of 25, by leileilol
I tried it out in PCem v17 on a Win98SE+SB16 guest and it sounds like the recording, its instruments are affected by previous MIDI songs so it sounds strange compared to playing it standalone (the pianos become something else). I'm still confident it's OPL3
long live PCem
Reply 19 of 25, by NiGHTSaturn
leileilol wrote on 2026-01-08, 14:31:
Which of the 2 videos are you referring to just to be certain? The first one as previously said is the only recording left of my old sound card, and the one I posted this morning is directly from the OPL3-128M sound font.
