First post, by DustyShinigami
- l33t
I just tried using Manty's Sound Blaster Pro Remote Control utility and I'm completely lost. Despite reading the readme and using the /? switch, I'm still confused with how you're supposed to activate and control the volumes. It says you press the HotKey (either A or ( for Alt or Ctrl) + Shift + PLUS and MINUS. Where do you do this exactly? Anywhere and at any time in DOS? Because when I tried nothing happened. Nothing happened in a game either. Or do you press A? Or (? Or do you type the name of the utility - SBPVOL.COM - and then A + Shift + PLUS? And how do you adjust the individual mixer options? Press M for Master Volume? Or type M1, M2, M3 etc? And can you only adjust the individual mixer options after you've activated the utility? Just with F1 and F2, F5 and F6 etc.? Things just aren't very clear to me at all. 🙁
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
