First post, by reale00
So for SNES and PS1 games I’ve set up CRT Royale to have chunky scan lines as they should be, at a thickness of 9 on a 2160p display. What I’m wondering though is if should I be disabling scanlines completely for gamecube and ps2 games since they used the full 480p or 480i resolution for a faithful representation of a CRT? Or do I still want to have thinner scanlines at around 4 thickness?
Reply 1 of 3, by leileilol
You'd still have scanlines there. 480i is pretty much 240 lines swapping rapidly, and Gamecube and PS2 games have variable methods to de-flicker (with buffer effects) to smoothen this out on the software side (though not all of them - early PS2 games are notorious for flickering).
I personally just use a NTSC shader and live with that. It could have a CRT shader over it (crt twitter going into shaders often forget the signal part) but i'm on 1080p and i'd rather keep the 'tv capture card experience'.
long live PCem
Reply 2 of 3, by theelf
I have yet to see a consumer CRT in sizes 14-21" (the most common ones) that is easy to appreciate scanlines in progressive content
