First post, by jimmy_choo
I've switched my old IO card (which was rusty and unstable) to the new one - Koutech 557A v2.0 (https://theretroweb.com/expansioncards/s/koutech-557a-v3-0 only v2.0) and my gotek flash floppy stopped working. The floppy is being identified (i.e. no error during the boot process) but when I try to open it with "A:" I get general failure error (although I see that led is blinking and gotek is trying to do smth). Unfortunately I don't have proper floppy drive to test.
The same exact flash works perfectly fine when I use old I/O card.
Is there a chance it can be fixed with some jumper settings or the new card is faulty?
