First post, by matti157
It's a strange setup, but I use an IBM T42 with it's original docking station that provides a PCI Slot.
I installed the Live CT4760 in that slot
I use the drivers by Philscomputerlab: https://www.philscomputerlab.com/sound-blaster-live.html
When I run the card initialization (sbecfg.com) I get the error: "SB IRQ conflicting with PCI IRQ"
HWINFO detects the card in the PCI 9, and in the BIOS I've already assigned the IRQ 7
Any ideas? It's an impossible setup?
The attachment IMG_3402.jpg is no longer available
The attachment IMG_3401(1).jpg is no longer available
The attachment IMG_3400(1).jpg is no longer available
The attachment IMG_3399(1).jpg is no longer available
CTSYN.INI:
[ctsyn.drv]
OPLPORT=388
MPUPORT=330
SBPORT=220
SBIRQ=7
SBDMALO=1
SBDMAHI=5
SBENABLE=TRUE
JOYPORT=200
JOYENABLE=TRUE
WAVESET=C:\LIVEDOS\EAPCI8M.ECW
PCIPORT=9000
PCIIRQ=9
[SBEINIT]
CONFIG=SBESET.CFG
[SBESET.CFG]
SBPORT=220
MPUPORT=330
SBIRQ=7
SBDMALO=1
SBDMAHI=5
OPLPORT=388
SBENABLE=TRUE
JOYPORT=200
JOYENABLE=TRUE
PCIPORT=9000
PCIIRQ=9
[SBEMIXER]
MasterVolL=250
MasterVolR=250
WaveVolL=250
WaveVolR=250
CDVolL=0
CDVolR=0
SynthVolL=250
SynthVolR=250
MT32=FALSE
DigitalSpeakerEnable=FALSE
Reply 1 of 2, by leonardo
Just a hunch, but I would not reserve IRQ 7 for the PCI device in the BIOS/firmware. A SoundBlaster Live! will consume two interrupts: one for the actual device and one for the emulated SoundBlaster.
It looks as if you reserved the IRQ you intended for the emulated SoundBlaster to use for a PCI device, which makes it unavailable to use for emulation.
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 2 of 2, by NeoG_
An SB card with emulation running in DOS requires two IRQs, one for the physical card and one for the emulation. Change the PCI IRQ back to auto select and set IRQ7 in PnP configuration to Legacy/ISA. That will result in IRQ7 being clear for the emulation and the PCI card having a different IRQ.
