First post, by bunghole102
Hello,
a long time ago, I built my own Windows 98 gaming pc with a mix of parts that I didn't really put a lot of consideration into at the time and I was wondering if I could get some insight into what exactly I put into my pc and whether or not I should invest in some different hardware.
First is the motherboard, which I originally poached from a Windows XP machine but have since replaced twice with an identical model, it is a PC CHIPS FSB266 K7 motherboard, model M811. I have looked around online and everywhere I have seen has suggested that this motherboard is not great, and that it is prone to failure or inadequate performance, which may or may not be true considering I've had to have it replaced on a couple different occasions now. Despite the apparent lack of quality, it has worked for many years and supports the rest of the hardware that I have in my machine. What I want to know is if this board is truly not worth my time, and if I should consider a potentially better option for my build.
Secondly, I want to know about the hard drive, which is some kind of no-name 160 GB IDE hard drive with a model number of WL160PATA872. This drive has worked flawlessly since I built the pc, despite the fact that a portion of if is not being utilized considering Windows 98's maximum hard drive capacity support, but I was also wondering if there was a better option out there regarding it. The drive has no apparent brand, although I can remember it being a purchase from Newegg that was relatively affordable at the time (I don't know if they still carry it.) Basically, I want to know if this is also something I should consider replacing, or if I ought to keep it, where could I potentially get a replacement, as I cannot seem to find another one anywhere.
Thank you for your feedback with these questions.
