First post, by vip11
Hello, I bought a Sony VGN-TT laptop (also called PCG-4Q1M). It had Windows 7 and everything worked fine. However, I prefer Windows XP, so I decided to upgrade. The laptop was generally optimized for Windows Vista, but it had official drivers for XP and Windows 7. Everything works on Windows XP, well, almost everything. I can't launch the program that controls the network devices: Bluetooth, LTE modem, and LAN. This is managed by the VAIO Smart Network program. For it to work, you need to install six programs one after the other, and finally, VAIO Smart Network. The program throws the error: screen.
The first reasonable step was to use the sfc/scannow command in the CMD, but it didn't work. I enabled the two necessary services (screen) and it still doesn't work for the same reason: 0x000006ba error
The system is the latest Windows XP version 2025, unofficial. Can anyone help me run this program?
Reply 1 of 2, by Falcosoft
vip11 wrote on 2026-03-05, 08:46:
As you can see this function is only available on Win Vista+:
https://learn.microsoft.com/en-us/windows/win … owmessagefilter
User32.dll (that exports this function) is a core component so I do not think you can do anything about it.
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 2 of 2, by vip11
Damn, that's really bad news. I won't change the system, and this program only allowed software shutdown of one device. Otherwise, instead of 3 at once, use the hardware button 🙁
