First post, by Dhigan
I am trying to get sound out of this nice hp compaq nx9420 under win XP64, but I can't make it work ...
https://support.hp.com/au-en/drivers/hp-compa … book-pc/1839153
sp41980.exe seems to be the right driver (ADI SoundMAX HD Audio Driver VERSION: 5.10.1.5240), but I get the following message : "audio driver installation failed"
It does mention PREREQUISITES : HD Bus Driver KB888111 must be installed first.
That would be sp32646 for win XP32 bit sp1 or sp2 (and not required for sp3 ?), but I have not been able to find Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio for XP64 bit ...
This MS support page does not mention a XP64 bit version
https://support.microsoft.com/en-us/topic/uni … b8-2551e825042e
material ID is :
HDAUDIO\FUNC_01&VEN_11D4&DEV_1981&SUBSYS_103C309F&REV_1002
I do have sound under win XP32 bit, so it is not a hardware problem.
Any idea how to proceed please ?
Win 3.1 : HP Omnibook 425 + Toshiba T2130CT
Win 9x : Dell Latitude Cpx H500GT + Dell GX1
Win XP64 : Asus P5B Xeon
Reply 1 of 11, by bakemono
Dhigan wrote on 2026-03-08, 15:33:
Is that what was reported in device manager in XP64? It probably already has UAA stuff installed. Check whether HDAUDBUS.SYS exists to confirm.
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 2 of 11, by Dhigan
Thanks bakemono for your input and sorry for my late answer.
hdaudbus.sys is found in c:\windows\system32\drivers and in c:\windows\Driver Cache\amd64\sp2.cab
Seem to be both the same version 5.10.1.5013 built by winDKK high definition audio bus driver v1.0a
Reply 3 of 11, by shevalier
https://pcsupport.lenovo.com/ua/en/downloads/ds003528
https://download.lenovo.com/ibmdl/pub/pc/pccb … q6aud08ws14.exe
Try these from the Lenovo website.
The problem with ADI is that Analog Devices did not post drivers on its website, but only provided them to manufacturers.
Then (I think) it sold this branch of the business to Connexant.
I don't remember exactly who bought Connexant, but it all ended.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 4 of 11, by Dhigan
Thanks Shevalier.
Yes "This package installs an updated version of the Microsoft Windows XP (64-bit) device driver for any ADI SoundMAX that comes preinstalled in your computer." also looked good to me...
But q6aud08ws14.exe (like sp45614.exe from HP) gives me : "does not support your computer hardware" ...
The funny thing is that, if I install a realtek HD driver like q6aud01ws14.exe or q7aud20ws14.exe they "install" without any error message but sound still doesn't work (yellow mark).
Reply 5 of 11, by shevalier
Dhigan wrote on 2026-03-12, 14:51:
Thanks Shevalier. Yes "This package installs an updated version of the Microsoft Windows XP (64-bit) device driver for any ADI S […]
Thanks Shevalier.
https://www.asus.com/me-en/supportonly/m2r32- … pdesk_download/
SoundMAX Audio Driver V5.10.1.6110 for Windows 2000/XP(WHQL) / V5.10.01.6110 for Windows 2003(WHQL) / V5.10.02.6110 for Windows 64bit XP(WHQL)/2003
These drivers in the ADIHdAud.inf file definitely have the line ‘dev_1981’.
Reply 6 of 11, by Dhigan
Thanks Shevalier.
Yes ADIHdAud.inf file definitely have the line ‘dev_1981’, well done !
But subsys is different : 10190E70.
In a wild move, I tried to replace the (one occurrence) subsys in the .inf with mine.
With or without replacement, I still get : "does not support your computer hardware" ...
Reply 7 of 11, by shevalier
Dhigan wrote on 2026-03-12, 18:04:
Thanks Shevalier. Yes ADIHdAud.inf file definitely have the line ‘dev_1981’, well done ! But subsys is different : 10190E70. I […]
Thanks Shevalier.
Try installing the driver via Device Manager by selecting the driver manually.
I have only dealt with SoundMax a few times, and always with problems.
Reply 8 of 11, by Dhigan
Thank you Shevalier for your patience and support !
Using "have disk" and pointing to your driver V5.10.02.6110 for Windows 64bit XP(WHQL) did "work". It complained though that it was not certified ... but I went with it.
The sound was glitchy (may be all the trial and error I did before ...) so I reinstalled win xp 64 but still glitchy. Worth noting that no additional SoundMAX software package was installed.
So it seems that HD Bus Driver KB888111 is not relevant to win XP 64.
I reinstalled XP64 with only the chipset driver and then the audio driver in case of conflict but same story.
I tried the "have disk" with lenovo q6aud08ws14.exe. Same story as with your driver (but no complaint about driver certification). When you read the attached document q6aud08ws14.txt on the Lenovo site, they talk of everything but nothing relevant to XP64. Except may be that "DirectX 9.0 or later is required".
Reply 9 of 11, by shevalier
Actually, there is a UAA for Windows XP 64-bit/Server 2003
https://catalog.update.microsoft.com/ScopedVi … bed2d5#Overview
https://catalog.s.download.windowsupdate.com/ … ol/10843509.cab
https://legacyupdate.net/download-center/down … dition-kb901105
Reply 10 of 11, by Dhigan
Thanks for this precision Shevalier.
This kb901105 seems to be included in the SP2 of winXP64, so the sound problem should not be related to the operating system.
Reply 11 of 11, by shevalier
Dhigan wrote on 2026-03-15, 12:37:
In the early 2010s, I used the 64-bit version of Windows XP for a very long time.
A Phenom X6 processor with 8 GB of DDR3 memory on a 785 chipset.
I had absolutely no problems whatsoever.
The operating system itself is excellent.
But with peripheral devices not by Realtek, there are always driver issues, whether it’s audio codecs or network cards.
