First post, by FullYes
Greetings
I recently acquired a MESH Athlon XP machine from ~2002. I bought it as tested and working and it does work, but it took me a while to realise there is quite a big issue with it.
It has an A7V333 v1.04 motherboard, though it is a bit of a stripped down "OEM" version as it does not have the RAID components installed.
https://theretroweb.com/motherboards/s/asus-a7v333
It originally had a 2000+ Palomino chip in but I successfully swapped to a 3000+ Barton. The computer runs stable as far as I can determine through stability tests and gaming.
The PC came with an Audigy card (SB0090) which didn't seem to work / detect properly. (I am running win98se) It shows up in device manager with a yellow exclamation mark saying the BIOS wasn't assigning it the IRQs it needed. I originally thought this was a card issue, but I tried it in another PC and got it working. I then bought an Audigy 2 ZS, which also didn't work (worked in another PC) I then tried enabling the onboard audio but this also doesn't seem to work, and neither do the USB 2.0 ports (the USB 1.1 ports all work fine)
I have a VIA PCI IDE / SATA card and a couple of NIC cards, and these all work fine.
I have tried using a few different version of the bios, but this didn't make any difference.
I have checked the jumper settings on the motherboard and have not found any reason to think that changing any of these will help - though I must say it is a dreadful motherboard for its use of MANY jumpers (certainly compared to other boards of its age)
Google searches and some threads on here mean my investigations so far point to it being an issue on the southbridge.
I am wondering if some bad caps would cause this issue, though it seems unlikely. The board has probably never been out of its case until I transplanted it into an antec case a few months back, so I don't think there are any damaged traces anywhere, but I will have a more thorough look at my next opportunity.
Does anyone have any suggestions?
System 1: K6-3 400, MS-5158 (430TX), 256MB SDRAM, Voodoo3 2000 PCI, AWE64 (Dos/95-early 98)
System 2: Athlon XP 2000+, SL-75KAV (KT133A), 512MB SDRAM, FX5900XT, Audigy 2 ZS (late 98)
System 3: i7-2600k, P8P67-M, 2x4GB DDR3-1866, GTX 460 (XP)
