First post, by dukeofurl
I've been having fun playing various 3d games on my Pentium ii with ATI 3d rage pro GPU. In theory my system meets all system requirements for ultimate race pro, and the game runs at a good framerate, however when I use the option for 3d acceleration, the graphics look like this.
The attachment IMG_20260421_105042.jpg is no longer available
The attachment IMG_20260421_105044.jpg is no longer available
The attachment IMG_20260421_105047.jpg is no longer available
I'm not sure exactly what this is, if it might be related to the lighting or reflections used in the game, or something else. There are various graphics options to turn off things like reflections and particles and gaurad shading, but even with these items turned off, the same graphics bug occurs. The bug goes away if I use the software renderer option, but then the game does not look or run very well 😜
URP is a direct x 5 game. I've reinstalled dx5 and it should be compatible with my GPU, which can also do dx6, and which works in various other late 90s 3d games I've tried.
I found there is a patch for URP to bring it up to v1.5, which had a few enhancements mainly targeted at 3Dfx cards... But installing the patch does not change the graphics.
I did some Internet research but didn't come up on anything about URP having problems with ATI cards. Any theories on what is going on here?
Reply 1 of 14, by marxveix
I will check this game out with my driver and let you know how it works there. ATi Rage Pro should work fine with Ultimate Race Pro.
Ultimate Race Pro has even drivers for ATi Rage Pro on its CD, so with correct driver and original version should be working normally.
Mostly ok with my driver, similar like in this video.Small white dots and some tiny lines sometimes, otherwise ok, not 100% perfect.
Strange that Rage Pro worked at better performance at this game than Rage XL, Rage XL had slowdown moments, but Rage Pro not.
ATi Rage Pro had more visible brake lines than Rage XL,all other at screen looked same on both cards and it was game version 1.0.0.1
Ulitmate Race Pro with ATi Rage Pro
https://www.youtube.com/watch?v=nQaRLZVgaj8&t=1887s
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 2 of 14, by dukeofurl
Very puzzling. Is the rage pro different from the 3D Rage Pro? My card has the latter name printed on it.
In the meantime, I've swapped gpus to a geforce2 on this system, and that has cleared up this issue with URP, though it's introduced a couple graphical artifacts and incompatibilities with early direct 3D games that I didn't have with the ati card, so I may swap back at some point 🤔
Reply 3 of 14, by marxveix
dukeofurl wrote on 2026-04-22, 17:08:
Dont worry, its Rage Pro, i have also 3D Rage Pro printed there with ATi3D logo. If its Rage Pro, then its Rage Pro, be it Rage Pro Turbo, XL, XC and others, mostly the same core.
https://www.techpowerup.com/gpu-specs/ati-rage-pro.g185
Have you used other drivers or what drivers are you using now?
Reply 4 of 14, by dukeofurl
marxveix wrote on 2026-04-22, 18:42:
I had done a fresh install of Windows 98 SE with this computer and during the install, it correctly recognized the card and installed a driver for it from the Windows install files. Seemed to work ok with other games.
Reply 5 of 14, by marxveix
dukeofurl wrote on 2026-04-22, 19:49:
I have never used Microsoft Win9x integrated drivers, cant say much about them.
Update 1.50: Rage XL slowdown fixed with newest patch update for Ultim@te Race Pro, but the latest update brings letterbox flashing lights issue (where it should be black area).
I will downgrade patch and look for the best suited patch for ATi (if that exist).Ultim@te Race Pro v1.2.1 is best for me and my ATi Rage3 cards: Re: ATi RagePro supported games
Reply 6 of 14, by dukeofurl
I am going to revert back to the ATI 3D Rage Pro card as the Geforce2 I replaced it with in my system seems to have incompatibilities with 96, 97 era very early directx / d3d games in that they either won't run at all, or will run with annoying graphical issues.
Is there a particular version of the ATI drivers I should try for good performance and compatibility? I'd like to try something other than the Win98 included driver just in case it will fix the URP issue, and perhaps give me faster performance with some games (Dethkarz for instance runs sluggishly at 640x480 with this card, and ran very noticeably faster and smoother with the geforce at same detail settings).
It sounds like I should also try version 1.21 of URP instead of v 1.5.
I was flipping through your forum threads about ATI cards. What is Rage Pro Tweaker? A program that will oc the card and provide greater performance?
Reply 7 of 14, by marxveix
dukeofurl wrote on 2026-04-23, 20:05:
For me URP v1.21 works better, less white small dots and lines, almost perfect. I think you can just change .exe file or add second one with different name (added .7z, game shortcut at default location and .bat file - both Direct3D+URace.exe). ATi Rage Pro Tweaker is tool for changing some ATi settings easier with Rage3, you can OC your Graphics card Ram and Core. I think its not gona hurt you to try my latest 5.40 drivers, it has glide2x.dll for some 3dfx games and this game automaically detects 3Dfx and you cant choose Directx (Direct3D) option. Ultim@te Race Pro does not work with added glide wrapper, just delete glide2x.dll from windows/system folder or start game with -d3d, then Directx (Direct3D) option available and you dont need delete glide2x.dll (wrapper file). Use High Color 16 bit at your desktop, many games need High Color 16 bit for Rage3 to accelerate. Use GlideWrapper @ ATi Rage Pro Tweaker with 565 settings / Some CIF games like 555 so turn it off with Tomb Raider (ATi version). Restart after setting change!
Try ARx2611x3Dfx.7z drivers with Ultimate Race Pro v1.21.7z added files and use Direct3D.bat or Direct3D shortcut and select DirectX from the Game.
ARx2611x3Dfx.7z download here: download/file.php?id=239658
More info here about latest ARx2611x3Dfx.7z driver (i use it at the moment) Re: ATi RagePro drivers and software
or use eariler ATi Rage Pro 5.38 or 5.40 drivers from first post ATi RagePro drivers and software
Hope you can get this game going with it and many others!
Reply 8 of 14, by dukeofurl
marxveix wrote on 2026-04-23, 23:17:
For me URP v1.21 works better, less white small dots and lines, almost perfect. I think you can just change .exe file or add sec […]
Awesome, this is fantastic! You seem like the definitive source about ATI cards 😎. I never heard much about them myself, but they seem decent and have good compatibility for the late 90s era of games I should be able to play with a pentium ii. Looking forward to trying out some new configurations with the drivers and tips you provided!
Reply 9 of 14, by dukeofurl
Fantastic! I used the drivers you pointed me to and the instructions you provided and now URP works just fine (with -d3d suffix)! Some other games I tested tonight seemed to run a little better than with the integrated drivers, so that's fantastic too! I still have yet to try the ragepro tweaker...
One thing - it seems my ragepro card may have only 4MB of memory on it. For the glide wrapper, I got the error that it needs 8MB of video memory, so that is a no go for me. I tried to delete glide2.dll in the windows/system folder, but it didn't seem to be there. My card does seem to have an expansion bay that looks like the one pictured below. Does this use a proprietary memory card? It would be nice to expand the memory. I'm very impressed with game performance and compatibility with this card.
The attachment aticard.jpg is no longer available
Reply 10 of 14, by marxveix
dukeofurl wrote on 2026-04-29, 02:32:
Good to know! File name is glide2x.dll, delete that or just click Glide XGL200.bat, that works with 4MB and you can try NFS2SE with 3DFX or some others (not perfect, but still). Inside Added folder there is Rage Pro Tweaker. Nice PCI Rage Pro card, still 8MB and AGP is bit faster Rage Pro edition. For OpenGL 1.1, use FastPerf or MaxPerf for better performance (Added/OpenGL folder). For lower 4MB and PCI card MaxPerf @bilinear disabled is fastest. OpenGL 1091 is good up to Quake2 based games and for Quake3 there are better OpenGL versions to use at Rage Pro. You can add 2MB or 4MB module and use up to 8MB for Rage3.
Reply 11 of 14, by dukeofurl
That's not my actual card, just a picture I found quickly of a card with the same module slot. Mine is agp 😎. What keywords should I search for to find the module online? Or are they too rare to find for sale these days?
Reply 12 of 14, by marxveix
dukeofurl wrote on 2026-04-29, 11:11:
If upgrade, then upgrade to 8MB and it should be cheaper to buy already with 8MB.
Like Rage LT Pro 8MB 2xAGP: https://www.ebay.com/itm/286233960744
Use Memory Module
100-401010 2M (4-6MB),also P/N 1024200200 (notsure about p/n) / 10ns memory
100-401012 4M (4-8MB),also P/N 1024200300 (correct about p/n) / 10ns memory
https://www.ebay.com/itm/306664838826?_skw=1024200300
https://www.ebay.com/itm/327122135643?_skw=100-401012
If you anyway uprade and the look of vga card does not matter, these are usually fastest Rage3 cards to choose (almost same compability as Rage Pro).
Rage XL AGP 8MB 2xAGP pn 109-66700-00
Rage XL AGP 8MB 2xAGP pn 109-66700-01
Rage XL AGP 8MB 2xAGP pn 109-66710-01
Reply 13 of 14, by dukeofurl
Thanks! I may actually buy just the module even if it's a little pricier. This is an OEM PC and it's fun to see what I can do with what it came with.
Reply 14 of 14, by marxveix
dukeofurl wrote on 2026-04-29, 14:31:
Rage Pro Tweaker has one setting for SGRAM if you want to install it. I think you already have better driver setup + add 4MB memory.
