altarofmelektaus wrote on 2026-05-01, 12:38:
I tried getting to the bearings to replace them as I am used to refurbing older fans like this, but the bearing itself is completely sealed off. I'm unsure how to get to it. Where you peel the sticker off on the back, there's just a metal cap.
Edit: I was able to get to the sleeve bearing just by pulling up on the fan itself. Interestingly simple design I've yet to run into before. It's pretty rusty and bad though, but some oil did actually help it start to spin. I'm going to look into carefully cutting a new heatsink for that piece though as I'm not seeing many cards with tiny heatsinks for the power regulation like I'd been imagining.
Good to hear that you were able to get the fan taken apart.
My usual encounter with these types of fans that have metal caps on the back (a few smaller Sunon Maglev's) haven't been so lucky so far - I just can't pull them apart without breaking them.
Now the newer fans that are "all-sealed" with plastic on the back - those I have figured out: just make a round cutout on the plastic where the shaft is, heat the shaft with a soldering iron (but not so hot to have solder stick to the shaft) so that the plastic locking retainer on the front side of the fan softens up, then finally pull on the fan blade assembly and it should break loose from the plastic locking retainer on the front.
Once the fan is taken apart, you can "deep-clean" the sleeve bearing by taking a really small flat heat screw driver and scrape inside the sleeve bearing opening in direction parallel to the shaft / bearing hole. This will create very tiny scratches that will act like micro-channels when the sleeve bearing is cleaned up and oiled again. So once you clean the sleeve bearing well via doing the scratching the with small screw driver, then push some paper towel balls soaked in IPA through the sleeve bearing opening. This should degrease everything. After that, apply sewing machine oil / light machine oil and re-assemble. The fan should work like new and stay that way for a long time.
Now, instead of making a new heatsink/cooler, have you considered just replacing the fan with something else?
In particular, if the original heatsink has "open" fins on the top (at least after removing any plastic shroud(s)), you can then just remove the original fan and install something else right on top of the heatsink. It sure won't look original, on top of making this a 2+ slot card... but who cares about that?! 😉 Well, to me at least, the card just has to cool properly and work right. How it looks is irrelevant. As a bonus, putting a fan directly onto the heatsink might allow you to install a bigger and possibly slower-turning / more quiet fan... so you get maybe the same or better cooling with less noise?
IDK, at least I'd try that first. Definitely easier than hacking together a brand new heatsink from scratch (though I have done that more than a few times too.)
shevalier wrote on 2026-05-01, 04:49:
Or, as an alternative to buying new ball bearings, you could just look for another fan that uses the same bearings and re-use those.
In my case, that's the preferred method, since on the flea market I go to, there's an electronic scrapper that always removed the fans from equipment and chucks them behind the place's fence. Not only is the guy littering, but he's wasting some perfectly good fans. Instead of complaining, though, I just pick up his "trash". The fans that are OK, I re-use as-is. But the way he removes some of the fans, he sometimes he breaks either their housing or the fan blades (or both), and these are only salvageable for parts afterwards - a good source for standard ball bearings, to me at least. 😉
