First post, by mt777
Someone asked me to check if reset button works in my mobo (as in his doesn't work). According to doc: it is J3.
Indeed, shorting doesn't make a reset. Maybe it is a factory issue with non populated element in route.
What reset should short finally then can measure to the end ?
