First post, by pccani
Hello everyone,
I'm trying to identify a removable drive module from an unknown computer system, probably from the early to mid-1990s.
What I know so far:
The module contains a Citizen U0DA-17A floppy drive.
It also contains an IDE hard drive.
The floppy and HDD are mounted one above the other inside the same removable carrier.
The carrier slides into a larger system and can be removed as a single unit.
A custom interface board is attached to the rear of the carrier.
The hard drive connects to this board through a standard IDE connector.
The floppy connects through a 26-pin FDD connector.
The carrier connects to the host system through a 50-pin Centronics connector.
On the host side there was a matching board with IDE and power connections, which converted IDE/FDD signals to the Centronics-50 connection.
The module is physically taller than a standard 5.25" drive bay, so it does not appear to be a typical PC mobile rack.
The PCB markings I found are:
PLO ECH 1
94V-0
E169497
Unfortunately I do not know the manufacturer or the original system it came from.
Does anyone recognize this type of removable drive assembly or know what computer/system it may have been used in?
Photo attached.
Thank you!
