SMP mod Gigabyte GA-6R7+
First post, by chubabs
Hi everyone, I'm trying to modify a couple of these slotkets. Maybe someone has already worked with them and can help
Motherboard - Soyo SY-D6IBA Rev 2.0
https://theretroweb.com/motherboards/s/soyo-sy-d6iba-rev-2-0
I had previously tried modifying a pair of Chinese 370CPUs, which I did successfully, but they refused to work together in Windows XP—it just kept crashing with blue screens. And when it did boot up, the system detected two processors but only used one.
Previous topic:
Slotket 370CPU SMP mod
So I decided to modify another pair of GA-6R7+ rev. 1.1, I performed the FCPGA2 mod and SMP mod, routing the b75 (slot 1) to N33 (socket 370). During a cold boot, the system would post every other time or more, and Windows would crash with blue screens. After reading some forums, I removed pin AN15, and Windows began to run stably on both processors during boot, but they still post every other time or more, and during a soft or hard reset, it gets stuck on the F5 post or others.
Each of the GA-6R7+ slotkets posts normally and reboots during a soft or hard reset individually.
Could you please suggest what else I can do, or look for a couple of other slotkits for this mod.
Reply 1 of 2, by chubabs
I don't know why, but on another motherboard, these adapters work just great—they reset and boot up on the first try—but on the SOYO, they just won't work.
Motherboard:
https://theretroweb.com/motherboards/s/tyan-s … 7un-thunderbolt
The only thing is that the core voltage needs to be adjusted slightly, but everything is working fine
Reply 2 of 2, by chubabs
Unfortunately, it still doesn't work. On the Soyo, it works when the POST passes, but on the Tyan S1837UN, it behaves exactly the opposite—it passes the POST every time but Windows crashes. It turns out the Gigabyte GA-6R7+ isn't suitable for the SMP mod after all.
