First post, by Im from Windows
Hello!
Have just bought a Sim City 4 CD and installed it on to my machine. I tied to open it and get an error message as in the title. Then I click ok, then it loads a black blank page and then quits the program.
Also did the same with Sim City 3000, no error message this time when loading the program but it just hangs.
Anyone know what it is please and how to fix it?
Thanks
Reply 1 of 19, by Im from Windows
PS how do I upload attachments to this forum please; so that you can all see that what i am doing is very wrong!
Reply 2 of 19, by Aui
Please specify " my machine"
Cpu:...
Ram:...
Video Card (and drivers if you know):...
Sound card:...
HDD:...
CD Drive:..
OS:...
Reply 3 of 19, by zapbuzz
they do not like more than 1 core CPU's
Reply 4 of 19, by Im from Windows
Aui wrote on 2026-06-14, 01:10:
Please specify " my machine" Cpu:... Ram:... Video Card (and drivers if you know):... Sound card:... HDD:... CD Drive:.. OS:... […]
Cpu:...
Ram:...
Sound card:...
HDD:...
CD Drive:..
OS:...
CPU? Acas Motherboard PTGD1-LA(Puffer M-UL8E)
Sound card; Gigabyte GV-NX72G512E2 NVIDIA GeForce 7200 GS 256MB DDR2 PCIe DVI Graphics Card
RAM 2.25GB
HDD 160GB
CD drive: speedplus
OS windows XP
Reply 5 of 19, by Im from Windows
zapbuzz wrote on 2026-06-14, 04:15:
i dont know what it is
Shall I remove the heat sink to find out?
Reply 6 of 19, by chrismeyer6
I know I used to play both games on my Core 2 duo xp system with no issues back in the day.
Reply 8 of 19, by MagefromAntares
Im from Windows wrote on 2026-06-15, 19:39:
dose this include pentium 2, 3 and 4?
Pentium 2 and 3 are single core processors. Pentium 4 processors often have Hyperthreading, which works like a virtual second CPU (It is actually a way to schedule operations from two threads simultaneously, so that the execution units of the CPU have less downtime, this is an oversimplified explanation of course, if your are interested in technical details there are a lot of articles regarding P4 multithreading going into various degrees of detail). There is also the Pentium D which is an actual dual core CPU, as it uses P4 cores sometimes these are referred to as Pentium 4 Dual Cores even if the official designation is Pentium D.
"A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it." - Dune
Reply 9 of 19, by Im from Windows
MagefromAntares wrote on 2026-06-16, 09:27:
Im not quite so sure what the processor is on this MB. How would I find that out please?
Pentium D. 64 bit right?
Reply 10 of 19, by MagefromAntares
Im from Windows wrote on 2026-06-16, 17:18:
You can use CPU-Z to identify the processor:https://www.cpuid.com/softwares/cpu-z.html
All Pentium D-s are dual core and 64-bit, there are two major variations, Smithfield which is basically two Prescott Cores put into a single package and Presler which is two Cedar Mill cores. While Pentium D-s are dual cores they are not the most efficient implementations of a dual core CPU as they are based on cores originally not designed for dual core usage.
Reply 11 of 19, by Im from Windows
MagefromAntares wrote on 2026-06-16, 18:26:
I was more thinking along the lines of actual looking at it, its selft to tell me what it is. or viewing system requirements or something in the BIOS rather then a 64 bit program that will not run on my machine
Reply 12 of 19, by Im from Windows
I found out! its a Pentium 4 . so no good then? unless anyone knows how to trick it in the BIOS?
Reply 13 of 19, by MagefromAntares
Im from Windows wrote on 2026-06-16, 19:46:
Actually 32-bit versions of CPU-Z is still available, it is only the default which is 64-bit, in-fact there is a vintage edition for Win9X computers too. However if you have WinXP and you just want to check if the CPU has HT or multiple cores you can open the "Task Manager", click on the "Performance" tab and if there is more than one graph under the CPU usage history it means there are either more than 1 Cores or in case of HT more then 1 thread of execution.
Im from Windows wrote on 2026-06-16, 20:38:
If it is a Pentium 4 that supports HT, chances are that the motherboard BIOS contains a setting to disable Hyperthreading, motherboard BIOS manufacturers like to put it into different options however so you might have to look around for it in the BIOS a bit. Most often it is called by its Intel name, Hyperthreading or shortened to HT, but sometimes it goes by the name of "Core Multi-Processing" or something similar when MB makers get creative with the naming.
The interesting thing is that WinXP lets you pin a process to a single core in the "Task Manager", but only after it is started, so if the program cannot start that feature doesn't help, Windows 2000 came with a utility called IMAGECFG.EXE which let you set an executable to be pinned to certain cores on a multiprocessor system, but weirdly Microsoft decided to not include it in WinXP. Also even more weirdly after they realised that programs might need to run on a single core when starting they made a utility called "psexec" that supported setting this, but that utility only supports Win 8.1 or later, so they kinda left WinXP users to disable Hyperthreading in BIOS or use third-party tools.
Reply 14 of 19, by Im from Windows
MagefromAntares wrote on 2026-06-16, 23:49:
Where is the task manager please?
Reply 15 of 19, by Im from Windows
I can tell you that when i boot it says its a "HP Invert v3.06" and a pentium 4. And that when i go into the BIOS its self it says "v02.54 copy write 1985-2004 American megatrends inc"
Reply 16 of 19, by MagefromAntares
Im from Windows wrote on 2026-06-17, 16:09:
Press Ctrl+Shift+Esc at the desktop and it should appear.
Im from Windows wrote on 2026-06-17, 16:12:
Unfortunately I'm not that familiar with that BIOS version and HP sometimes did some customization to it, so I cannot say where and how that option is exactly named or if it present at all, maybe someone with more specific knowledge about this configuration can tell where to look.
Reply 17 of 19, by Im from Windows
MagefromAntares wrote on 2026-06-17, 17:51:
maybee I should post the question in a better part of the forum to find someone that might?
Reply 18 of 19, by zapbuzz
pentium 2 and 3 are single core and pentium 4 is single core or single hyper threading.
on pentium 4 you can disable hyper threading in BIOS to force single core single thread.
Single core single thread should allow your mentioned games to run.
If not, I suggest looking at GPU and RAM.
Reply 19 of 19, by Im from Windows
