First post, by auntyellow
I've been experimenting with the games included with Windows and found that many of them can actually run on much older OSes and lower-spec hardware than you'd think.
Here are some interesting results from my testing, along with online playable links:
  • FreeCell: Windows 3.0 Real Mode
  • Hearts: Windows 3.1 Standard Mode
  • Spider Solitaire: Windows 95 with only 4MB RAM
  • 3D Pinball: Windows 3.1 386 Enhanced Mode with 8MB RAM
  • Fury3: Windows 3.1 enhanced mode with 16MB RAM (running via js-dos with the DOSBox-X engine)
(Note: I didn't include Reversi, Solitaire, or Minesweeper since they are already widely available in standard Windows 3.0/3.1 web emulators.)
Curious to hear if anyone else has managed to push these games onto even lower specs or weirder setups! Enjoy!
Reply 1 of 4, by jakethompson1
It makes sense as these often came from somewhere else originally. FreeCell is from one of the Windows Entertainment Packs, and 3D Pinball is Microsoft's adaptation of Full Tilt! Pinball.
Reply 2 of 4, by zapbuzz
3D pinball had a few cosmetic changes over the years pity the unofficial 64bit port is not accurate.
Reply 3 of 4, by leileilol
Fury3 supported Win32s and doesn't need 16mb. I've played it on WFW back a 1995 ago on a 8mb 486
long live PCem
Reply 4 of 4, by auntyellow
jakethompson1 wrote on 2026-06-20, 03:17:
I had always thought FreeCell was firstly introduced in Win32s, until I found it in Windows Entertainment Packs.
leileilol wrote on 2026-06-20, 06:11:
Sorry I've forgot to increase swap file (originally 0.5M). Here's the update:
  • 3D Pinball: Windows 3.1 386 Enhanced Mode with 2MB RAM + 8MB Swap File
  • Fury3: Windows 3.1 386 Enhanced Mode with 4MB RAM + 16MB Swap File (running via js-dos with the DOSBox-X engine)
Performance doesn't seem to drop.
