First post, by bbence84
Hi! I have found the following PCI network card for cheap on a local auction site:
https://www.vatera.hu/cisco-aironet-350-pci-w … 3505622036.html
It looks as if the wifi module is exactly the same as the PCMCI card of the same name, with the exception of the antenna piece.
Do you think I could remove the module and use it it a 486 laptop? (Siemens Nixdorf PCD-4ND, AFAIK it has a 5V PCMCIA card slot)
Or are these completely different modules?
Thanks!
Bence
