First post, by biggieshellz
Hi all -- I have an Omnibook 425. By default, it runs partially off of the D: drive, which is a flash ROM containing a basic DOS/Windows install, and it's not possible to boot strictly from the C: drive or install an OS other than the one contained in flash ROM. However, I understand that with the flash ROM from the Omnibook 430, things are a lot more flexible, and you can install other OSes.
Does anyone know if the Omnibook 430 flash ROM image (v2.0s) is available anywhere? If so, I have a friend who would be able to write it to a linear Flash PCMCIA card to use with my machine.
Thanks!
