GOG Pirates! Tandy mode
First post, by FeedingDragon
I wanted to play Pirates! again, and had purchased it on GOG. Reading up on it, I wanted to play in Tandy mode for the much improved audio along with the EGA quality graphics. However, the DOSBox provided by GOG apparently has a bug with Tandy graphics that was fixed in later versions of DOSBox. The problem with just using a fixed DOSBox is that GOG has patched the MOUNT command to include the "-t overlay" option so that C: is first mounted as the game directory, and then the "cloud_saves" directory is mounted as C: with the "-t overlay" option, so that writes to C: go into the overlayed directory instead of the main directory.
So, I either lose Tandy audio or lose the ability to keep backup saves on the GOG cloud. Is there a version of DOSBox that includes the overlay option to the MOUNT command?
Feeding Dragon
Reply 1 of 5, by SScorpio
What version of DOXBox did you try using? The vanilla version is very limited. But any of the common forks DOSBox-X, DOSBox Staging, etc should do what you are asking.
Reply 2 of 5, by FeedingDragon
I used the download version (0.74-?) from the main site, several months ago. I haven't tried any of the SVN versions. I tend "not" to use 3rd party versions. I do, however, have a self-compiled version which includes several patches I like.
Feeding Dragon
Reply 3 of 5, by SScorpio
The latest official release is 0.74-3 and it was released June 2019. You could try the SVN versions if you really want.
But if you haven't tried the forks, you're really limiting your experience. They've added so much over the years, you should at least give them a try to see if any meet your needs.
DOSBox Staging - Adds a bunch of additional sound devices, quality of life features. And simplified CRT emulation.
DOSBox-X - Focuses on accuracy dropping being just for games and can run Win 3.1 and 9x as well as other OSes that ran on top of DOS. It tries to be an accurate full computer emulator.
DOSBox Pure - Tries to simplify the experience, making DOS gaming work more like a console emulator.
There's a program which will let you easily swap in DOSBox Staging into GOG installations.
https://github.com/Shin-Aska/DosboxStagingRep … cerForGOGGalaxy
Reply 4 of 5, by FeedingDragon
Do any of these (or any official releases 0.74-3 & SVN,) include the "-t overlay" option for mount?
Feeding Dragon
Reply 5 of 5, by ripsaw8080
Rank DOSBox Author
DOSBox Author
FeedingDragon wrote on 2026-08-06, 02:36:
Though modern forks of DOSBox likely have adopted it, the overlay feature devised by Qbix originated in SVN. There is no official binary build/release, but a good Windows build of the latest SVN source is available from Yesterplay80's site via IA: https://web.archive.org/web/20240430023008/ht … SBox%20r4482.7z
