First post, by Ha3keye
Does anyone have documentation for this mainboard, or can help me with the following?
Every start a message appears that the CPU fan ist missing. It's a 5-pin connection. I can measure the pins = 12V / NC / 5V / GND / GND. Can I connect the 5V output (speed?) to GND?
Already tested several 72-pin SIMM modules, none of them worked. Which types should I use?
I couldn't use the SCSI CD-Drive unser DOS. Need the correct NCR SCSI Driver with settings in autoexec.bat and config.sys.
With Windows 98SE (installation separate ISA/IDE) the CD-Drive works.
