First post, by NovaXPT
Hi there,
I have some weird issues with a Gravis Gamepad Pro I bought on ebay.
The "Joystick" is constantly moving left. Additionally both buttons on the right front are constantly pressed (marked in screenshot, Button 1 flickers between up and down) . As one button also moves the X Axis (I assume as at least the one on the left side does this), I suppose that somehow both buttons are not working and all other buttons including the stick control seem to work.
I cleaned it but no change.
I am running Gravutil and MS DOS. I grid mode it is detected with similar issues.
The only capacitor seems ok. As I don't have much experience fixing this apart from changing capacitors I am a bit stuck. Anybody already had a similar issue?
Thanks for your help.
