First post, by OccasionalEnthusiast
Hello everyone!
I really need some help identifying a particular graphics card just by its IO shield/ports. Its a dual slot one (an important factor here) with dvi, vga and s-video in this order. The combination of ports was common around the year 2004 or so, but for the life of me, I cannot find one which is also dual slot, like the one on the picture below.
Many thanks already in advance!
Reply 1 of 5, by wierd_w
DVI, VGA, SVideo (TV Out)
Probably an ATI card of some flavor.
ATI with TV Out was a gimmick in the mid 90s.
Dual slot *might* be radeon though.
The ports are in the wrong order to be this guy-- this is just to show the existence of dual slot occupancy flavors of these cards actually existing.
https://www.worthpoint.com/worthopedia/sapphi … 56mb-1792560025
The grille type for the cooler at least matches.
Again, gonna suggest some variant of late ATI / Early Radeon.
Reply 2 of 5, by OccasionalEnthusiast
Yeah, all of the cards I've been able to find so far with these ports and being dual slot, had the s-video one in the middle, just like the one in your link. Found more Nvidias myself though, among them also 5800 ultra (that would be a find, eh?), but not a single card with this exact setup.
Reply 3 of 5, by Dothan Burger
OccasionalEnthusiast wrote on 2026-09-08, 15:54:
I think it's either a HD2400 AGP or an 8600GT. Probably an OEM card they didn't want anyone using the slot below Just a guess!
I would think if it were FX5800 you'd see the inside of the fan shroud through the vents.
Reply 4 of 5, by havli
My guess would be something of 2004 - 2007 era. Cards before 2004 were single slot and cards after 2007 didn't have svideo. So likely some kind of GeForce 6/7/8 or Radeon X1000/HD 2000 series.
Looking at the design of the second slot bracket, it very well could be Gainward brand - like this 8600 GT https://www.classicvga.com/product-page/gainw … 0-gt-512mb-ddr2
Reply 5 of 5, by OccasionalEnthusiast
havli wrote on 2026-09-08, 19:10:
I think this is IT! I knew this would be the best place to inquire (even though I couldn't even remember my original username from years ago). I should have posted this immediately, instead of wasting an embarrassing amount of time trying to suss it out myself. The problem is, you don't really have a comprehensive list for cards this old; sure, Techpowerup's database is great for those around 2010 and newer, but for older stuff, it's quite spotty or sometimes even non-existent. For instance, you only have 3 8600gt cards in there and none of them are from Gainward. I did initially suspect a card of this generation (the Asus one has the same configuration of ports, but is single slot), but when I wasn't able to get a match, I broadened my search, which just got me nowhere... Many thanks for this!
