First post, by muon
I have a Soyo SY-4SAW motherboard with 64MB of RAM (two 32MB FPM modules). It had been sitting idle for a long time, so yesterday I took it out to run some preliminary checks before installing Windows 98SE today.
It passed those initial checks without any issues. The testing consisted of running a few utilities: CheckIt and other and the standard Memtest86. All was ok.
Today I started installing Windows 98 and ran into trouble: when `config.sys` loads, HIMEM reports a memory error.
Damm —one of my memory modules must have died. That’s usually the case when HIMEM fails its self-test. But I’ve run Memtest86 several times since then, and it says everything is fine. ???
Can anyone point me in the right direction? What’s the problem? Is it a configuration issue?
Thanks in advanced
Reply 1 of 7, by devius
Have you tried to run it with just one of the memory modules? With other memory modules?
Retro Coisas no YouTube
Reply 2 of 7, by muon
I haven't run that test yet; I haven't had the time.
I'll also try those modules in another motherboard. However, I suspect the problem might lie elsewhere.
I believe the MemTest86 test is much more rigorous than the HIMEM test; the latter relies on the BIOS and other factors, whereas the former accesses the memory directly.
I think it's a setup issue. That’s why I’m asking if anyone else has encountered this problem and how they fixed it.
Reply 3 of 7, by wierd_w
I see broken images in the initial post. Cant see them.
Reply 4 of 7, by Matth79
Memtest pass points to something else, maybe the cache, cache timings? Not sure if memtest disables cache, but it must work in a way that avoids cache hit
Reply 5 of 7, by dominusprog
Start with the basics. First, check all the contacts on SIMM slots carefully for missing or bent pins, then clean the contacts on both the SIMM slots and the RAMs with a contact cleaner or IPA.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 6 of 7, by majestyk
HIMEM reports errors no matter if RAM or Cache (SRAM) causes them. In many cases an "ageing" TAG-RAM is the culprit.
Reply 7 of 7, by MikeSG
If both sticks pass HIMEM when installed on their own (single stick), it's possible RAM or cache timing is too tight. Windows 95/98 loading exposes some system instability.
