First post, by Knaxia
I've got a little personal project for a very specific type of build, but I have a hard time picking between two motherboards. I won't go too much in details but the two options I have are pretty much identical, apart from the Chipset and CPU support. They are both the same brand, all the same options in ports, internal slots, and so on.
-One is a Socket 478 for Pentium 4 , with SiS 648 & 963 chipsets
-One is a Socket 462 for Athlon XP, with SiS 746 & 963L chipsets
The 478 supports max 533 FSB and DDR 333. I have a P4 2.8Ghz 533Mhz that I already have will likely be the CPU I put in there.
The 462 supports max 333 FSB and DDR 333. I have an Athlon XP 2800+ 333Mhz that will be the CPU that goes in it.
The boards only have 2x DIMM so it will likely run 2x 256MB or 2x 512MB DDR 333.
I guess at this point, it turns down to two things:
-The classic P4 vs A-XP at the same "rating". I am not home right now, so I cannot check or remember which version I have of the P4 (Northwood or Prescott) or the A-XP (Thoroughbred or Barton).
-Which of both platform was the SiS chipset better optimized for in term stability, performance, compatibility and so on.
The system will mostly be used for some benchmarking and testing parts, and some old 3D games, will be running with Windows XP. There is no AGP slot on the system due to a onboard chip, which is the base reason of the purchase and I do not want this to affect the final decision.
