First post, by Simmerhead
Hi all!
What joysticks did you use back in the late 1980s, early 1990s to play DOS games - and were any of them any good?
I didn't get a joystick for the PC until Flight Simulator 98 came out. Before that I was a keyboard-only man. Anything I tried for the PC was terrible compared to the joysticks I had for my Commodore 64 and Amiga 500. Now that I'm all into vintage PCs I'd like to seek out some authentic time appropriate joysticks or game controllers for EGA/VGA DOS games, preferably ones made before 1995. Any suggestions?
Simmerhead
¤ VGA-era DOS Gamer
¤ Vintage PC Hardware Collector
¤ Big Box DOS Games collector
Reply 1 of 17, by gerwin
Simmerhead wrote on 2026-11-15, 17:42:
Hi all!
I had a Quickshot joystick QS-123 back then. It broke down after significant use. So I bought another QS-123 to replace it. Cannot really compare it to other offerings though. For Windows/USB I switched to MS Sidewinder precision pro.
Reply 2 of 17, by MAZter
Here is my choice:
The attachment PXL_20260908_104756030.MP.jpg is no longer available
Doom is what you want (c) MAZter
Reply 3 of 17, by Simmerhead
MAZter wrote on 2026-11-16, 17:17:
Here is my choice:
That looks like a great one!
Simmerhead
¤ VGA-era DOS Gamer
Reply 4 of 17, by Half-Saint
Always used the keyboard to play games. Only used the stick for flight sims.
Reply 5 of 17, by Simmerhead
Half-Saint wrote on 2026-11-17, 16:40:
Yep, me too. It wasn't until I got my Pentium 60 that I had a game port for the very first time. There was nothing for the PC that could compete with the joysticks I had for my Amiga 500, so I never bought one.
I've ordered the following from ebay just now, and hopefully those action games will become a little more fun now:
Simmerhead
¤ VGA-era DOS Gamer
Reply 6 of 17, by dr_st
All gamepads suck. Joysticks make sense if you need analog precision. Fighting sticks make sense for, well, fighting games, but even those could be better with a keyboard if programmers actually programmed it properly.
https://cloakedthargoid.wordpress.com/keyboards-vs-gamepads/
Reply 7 of 17, by Joseph_Joestar
dr_st wrote on 2026-11-19, 08:54:
I also found it easier to play the Mortal Kombat games via keyboard. And I have played them for years using a (Sega MegaDrive) gamepad before that, so I have a lot of experience with both. Sadly, most PC keyboards from that time couldn't handle key rollover very well, so pushing more than three keys simultaneously would not register any further input. This sucked if you wanted to play together with a friend on the same keyboard.
On topic, my personal controller preferences are as follows:
DOS:
I rarely use a controller here, but I do like the CH Flightstick for space sims and such. Maybe not the best one around, but it feels comfortable in my hands.
Win9x:
Logitech RumblePad 2. It's basically a PC compatible clone of the PlayStation 2 controller. You get two analog sticks, rumble support, and a whole lot of buttons. Works fine for DOS games too, when they are played from within Win9x. Has official Win9x driver support.
WinXP:
The aforementioned Logitech RumblePad 2 for pre-2006 WinXP titles, and an Xbox 360 controller (wired) for anything newer. The Xbox 360 controller has official driver support for WinXP and any newer Windows version, and it's pretty painless to set up and use.
Win10 and up:
Xbox One/Series X controller (same thing basically). Most games from the 2010s (and newer) support it out of the box, and need no manual configuration. Get the official wireless adapter for lower input latency and you're all set. Uses a pair of standard AA batteries that you can easily swap out when they start running low. Super convenient if you use rechargeables.
My retro stuff
Reply 8 of 17, by dr_st
Joseph_Joestar wrote on 2026-11-19, 09:33:
Win9x: Logitech RumblePad 2. It's basically a PC compatible clone of the PlayStation 2 controller. You get two analog sticks, r […]
Win9x:
WinXP:
Win10 and up:
I have the controller to cover both worlds - The Logitech F510. It's a Rumblepad 2 with a DirectInput/XInput HW switch. There is a cordless variant (F710).
Some folks complain about dead zones on the Logitech F-series controllers. I found Speedlink gamepads interesting in this regard, many of them also have hardware D/X switches.
https://cloakedthargoid.wordpress.com/logitech-speedlink-gamepads/2/
Reply 9 of 17, by RetroGamer4Ever
Logitech is my go-to. I have found a few brand new older units and a lot of newer ones, in thrift store piles. I've also gotten several complete Thrustmaster HOTAS rigs and a lot of Logitech and other brands for Flightsticks.
Reply 10 of 17, by Jasin Natael
I used a ProPad 6 back in the day.
I'm not saying it was the best, pretty far from it. But that's what I had anyway.
Reply 11 of 17, by jh80
Your blog was more sensible than your post.
First, yes, obviously it all comes down to what is most comfortable for each individual.
Regarding fighting games, which is what you seem focused on: although arcade sticks are very popular, many players prefer the "hit box" controller (buttons only - no stick), which is similar to using a keyboard like you prefer. One big difference, though, is that the hit box controller will have separate buttons for each finger for movement. It is less than ideal to use your middle finger for both up and down (finger travel = bad), although as with any control method you can get used to it. So, for that reason, I wouldn't call the keyboard better, all else equal.
Regarding gamepads, the main advantage of which is comfort or possibly intuitiveness for some players, you really have to try some better gamepads if you want a good dpad. None of the gamepads on your blog are focused on dpad-based gaming. It's not really fair to say "I tried all these cheap Logitech gamepads and I couldn't do diagonals well. Therefore, all gamepads suck."
The best dpad ever created was the one on the Japanese Sega Saturn controller (in my and many others' opinions), and it is faithfully recreated on the 8bitdo m30. You will not miss diagonals. And it has 6 face buttons which works great for games like SFII.
A gamepad may not offer the most precision, but for many people it offers the most comfort, so blanket statements like "all gamepads suck" is just off the mark in my opinion.
Reply 12 of 17, by swaaye
I used a CH Flightstick for joystick games. It is friendly to left handed people.
I also had the SNES style pad above but I didn't really play much of those sorts of games on PC.
Reply 13 of 17, by Nicolas 2000
We're talking gameport? I had a Logitech Wingman Extreme which I played to death. It came bundled with Descent II in its own slim bigbox.
The (Thrustmaster) Top Gun joystick was also available with Gameport, I think as far as cheap ones go that one is quite OK.
Back in the day, if you really wanted to impress people you played Falcon 3 or 4 with a HOTAS.
As for gamepads, Guillemot was quite an OK brand in the day.
Reply 14 of 17, by Law212
I also found it easier to play the Mortal Kombat games via keyboard. And I have played them for years using a (Sega MegaDrive) g […]
DOS:
Win9x:
WinXP:
Win10 and up:
This
Though I do use A microsoft sidewinder for flight and space sim games like x wing on my 486.
on my pentium 1 i use a sidewinder gamepad
on my pentium 3 and 4 I use a wireless rumblepad 2 though i used to use an xbox 360 pad on pentium 4.
and on PC i use an xbox one gamepad.
Reply 15 of 17, by BaronSFel001
"Best" is subjective and contingent on variable use factors. What will last because it has had more than long enough to stand the test of time? Early Thrustmaster (the ones made in the USA) set the standard, but moreso and to this day CH Products are built like tanks. Microsoft Sidewinder followed a similar philosophy, though their durability is more due to the inherent resilience of using contactless hall sensors instead of traditional potentiometers.
I have no experience with older Logitech designs but have heard more good than bad things about them, and some of their designs (like Wingman Warrior's twist knob for FPS games) have the virtue of being unique.
System 20: PIII 600, LAPC-I, MK1869 Xtreme, Voodoo3, SQ2500, R200, 3.0-Me
System 21: G2030 3.0, X-fi Fatal1ty, GTX 560, XP-Vista
Retro gaming (among other subjects): https://baronsfel001.wixsite.com/my-site
Reply 16 of 17, by dr_st
jh80 wrote on 2026-11-19, 22:14:
This is an interesting approach. I may try it one day, although I am actually far less of a fighting game player that reading that blog post may make it seem.
That was my point. Once you get a Gamepad for D-Pad based gaming - you've already lost, in my opinion. For D-pad based gaming, a D-pad will always be inferior to a good keyboard. It's like the opposite end of the fighting stick. Instead of dedicated finger for direction you use your thumb for everything. A keyboard sits somewhere in between. It may not be as precise as a hit box controller for fighting games, but it is more versatile.
I have one of those original Sega (SLS) Saturn USB controllers. Got it precisely because of its renowned D-pad. I was underwhelmed. It feels great and very solid, but I didn't feel it performed noticeably better.
Reply 17 of 17, by badmojo
I'm a big fan of the Microsoft SideWinder 3D Pro after trying quite a few over the years. But all I use these days for my joyport-only PC is an InterAct MakoPad PC. It's a nice pad with an analogue stick that works in DOS - you can switch between D-pad and stick.
