First post, by Sly_Botts
Hey guys,
I was recently able to purchase a new old stock ASRock 775i65G rev 2.03 motherboard from an eBay auction for a very reasonable price. Everything appeared to be in order except for one capacitor near the CPU. The area where the capacitor is installed is labeled Labeled CE717.
The attachment IMG_20261119_140140069.jpg is no longer available
The attachment IMG_20261119_140126214.jpg is no longer available
As you can see there's some corrosion at the top.
The recommended replacement is Panasonic EEUFK0J681
Electrolytic Capacitor, FK Series, 680 µF, 6.3 V, ± 20%, Radial Leaded, 3000 hours @ 105°C, Polar
My question is, I have a ton of donor motherboards and a few that I'm probably never going to use ever and probably should be just trashed. I can't find any capacitors on these motherboards that are exactly the same. Should I just order the replacement or is there a possibility of a safe donor capacitor from one of my old motherboards? I also have some brand new Panasonic FS0J332 with a Capacitance of 3300 µF and Voltage of 6.3 V. Original capacitor was four volts but apparently 6.3 volts is safe. Now I know that as long as you meet the minimum capacitance you're safe, but I was just curious if it would be safe to use this capacitor since the capacitance is so much higher or if I should just order the exact replacement. I just don't want to have to go through all the trouble just to order one capacitor.
Thanks for the advice.
It is possible to commit no errors and still lose. That is not a weakness, that is life.
Reply 1 of 1, by Ozzuneoj
I can't quite tell from the picture, but is that a TMJ series capacitor? It should have a three letter sequence like that on it somewhere. I found this:
https://www.badcaps.net/forum/general-topics/ … ppon-tmj-series
Basically, if that's what it is, they seem to be related to a series that is known to be bad... from an otherwise very reliable brand. The issue is that those are likely ultra low ESR capacitors. The replacement one you linked to is just labeled as "automotive" and has much higher impedance.
I am not experienced enough to say whether you can replace a 680uf with a 3300uf in this situation, but the Panasonic FS is a standard, not low-ESR cap. That said, because that is a physically much larger cap it may have similar ESR to the little Ultra Low ESR cap. So, if the capacitance doesn't really matter then it might work. But, I wouldn't guess at that. Also, a larger cap may get in the way of other things in that location, like heatpipes on larger heatsinks.
Given the rather unusual 4V rating, a polymer cap could be a better fit. You may be able to harvest one from another old motherboard or video card.
