First post, by NEx
i've been farting around with this for a couple of days now. I am able to create a hard disk image using bochs without issue. I'm able to use FDISK to create the partition and set it active. When I try to format the partition I've created i keep getting a Disk write error and cannot proceed. I'm attempting this from a Dual Core 3800+ with XP pro SP2 but also from Virtual PC's runing Xp Pro sp2, win98, etc.,
any insight would be appreciated.
