First post, by DDRmaster
I'm a neanderthal when it comes to this stuff and I have no clue how to get a game working.
I made a folder on my D drive called "veryoldgames" and tried mounting it. I doubt I did it right, though.
I also installed Redneck Rampage in that folder. However, I don't know how to run the games with DOSbox.
Please! Help me. Anything is greatly appreciated.
-DDRmaster
Reply 2 of 11, by DDRmaster
Okay.
I got the stuff mounted according to the guide. I had to install through Windows rather than using DOSbox because it kept getting an error while archiving.
Now how do I actually run it... Hmm.
Reply 6 of 11, by Kippesoep
It isn't for most of us. Without more information, we still won't be able to tell what you might be doing wrong.
Personally, I'd bet on the game not being properly configured through its setup program. Also, note that Redneck Rampage is a relatively recent game and might not run optimally under DOSBox if your system isn't seriously high spec-ed.
My site: Ramblings on mostly tech stuff.
Reply 7 of 11, by wd
Rank DOSBox Author
DOSBox Author
No, once you know what to do it takes a few seconds (copying/unpacking
the game, installing it if necessary, reconfiguring it and running it).
About sound: see if the game has a setup.exe or setsnd.exe or any kind
of installer. Run it and select Sound Blaster 16 with irq=7 dma=1 addr=220.
