First post, by dhruba.bandopadhyay
This is to honor and keep Blood multi-player alive. It is still possible to play Blood over the internet or LAN under Windows XP SP2 or Vista*. There are 2 main working ways:
1 - DOSBox (XP/Vista, handle max 2 players because it's DOSBox)
OR
2 - Hamachi (up to 8 players, 98/XP only, needs PC with 32-bit CPU, eg. original P4)
1 DOSBox
Thanks to aabluedragon (creator of Dukonnector http://duke3d.vachu.com/) who is first person to setup Blood over internet via DOSBox successfully - and now his Dukonnector can help connect Blood players together.
Quick guide to DOSBox multiplayer, client type:
ipx=true
ipxnet connect <server's ip> 23513
(where 23513 is your chosen port and the server has to port forward /open this port on his router. Port number is optional, and the default is 213 for DOSBox (I think).)
The server types:
ipxnet startserver <port>
(if you don't specify a port, then 213 is used by default for DOSBox).
OR
2 Hamachi
I have tested this and it works, even behind a router/firewall.
My working setup:
 - Hamachi version 1.0.2.5, or 1.0.3.0
 - Hamachi settings default, but ensure you have:
 -- System | (check) Do not use Universal Plug and Play
 -- Security | (uncheck) Block vulnerable Microsoft Windows services
 - In Network Connections install NWLink IPX/SPX/NetBIOS Compatible Transport Protocol
 - In Hamachi Network IPX Properties (not your normal internet connection):
 -- Internal network number: 00000000
 -- Frame type: Ethernet II
 -- Network number: 00000101
 - In Hamachi Network TCP Properties (not your normal internet connection):
 -- (tick) Obtain an IP address automatically
 -- (tick) Obtain DNS Server address automatically
If you are interested in playing over the internet then please reply to this thread. It will be good to get 4 - 8 player games going on, on a weekly basis.
I will keep here an up-to-date list of players who submitted their MSN/YAHOO messenger usernames publicly:
aabluedragon@gmail.com (MSN)
denizsi@hotmail.com (MSN)
oleolaussen65@hotmail.com (MSN)
rogerhaarr@hotmail.com (MSN)
Just add them to your MSN/YAHOO messenger and hopefully you will have 3 Blood players for a 4 player deathmatch!!!
Also, this is an excellent alternative for Blood Buddies:
http://forums.transfusion-game.com/viewtopic.php?t=1149
* - Vista? only via DOSBox, which is really DOSBox platform rather than Vista itself.
