First post, by MikeSol
When I pull the inventory window all the way to the top, the graphics get corrupted. I have to keep it just slightly away from the top to prevent this. Is there a fix for this? Thank you.
Reply 1 of 4, by MiniMax
Rank Moderator
Moderator
Known problem:
Graphic glitch in Event Horizon games
(the search function works really well for non-lazy people)
Not much you can.
_________________
Reply 2 of 4, by MikeSol
Not lazy, just absent-minded. It did not occur to me at the time to try a search first. My apologies.
If I am reading that info correctly, a solution was found but I guess I will have to wait for a future version of DosBox for implementation.
Reply 3 of 4, by MiniMax
Rank Moderator
Moderator
You can try one of the un-official (read: upcoming) builds of DOSBox and see if one of the planned changes will fix the problem:
DOSBox SVN Builds
_________________
Reply 4 of 4, by MikeSol
There was indeed a build of DosBox at that link that fixes the game. Thank you!
